Front axle U-Joint replacement
Old Apr 6, 2010 | 12:02 AM
38146's Avatar
Can someone please direct me to any thread that lists the sequence for R&R of the front u-joints in my 2006 3500 4x4 Dodge Ram Dually? Thanks, Dan H
Old Apr 6, 2010 | 10:07 AM
alltimelow1's Avatar
https://www.dieseltruckresource.com/...+joint+replace
This has all the info you need to know! Not too hard, just be careful pulling your bearings not to damage them.
Old Apr 6, 2010 | 01:36 PM
annabelle's Avatar
U joints?
Old Apr 6, 2010 | 02:46 PM
booman70's Avatar
Well that thread you need to follow up to pressing the ball joints out if not doing ball joints. At that point just replace the front u joints as you would any other u joint.
Old Apr 6, 2010 | 08:36 PM
38146's Avatar
Thank you, 38146
Old Apr 6, 2010 | 08:57 PM
1985cucv's Avatar
no no no no..... my u joints came out so hard i couldnt believe it. i had to buy three of them cuz i broke one putting it in they were extremely tight so get your torch ready
Old Apr 8, 2010 | 04:34 PM
booman70's Avatar
Mine were very tight also use a lot of PB Blaster I've done them with a old socket and a BFH and a ball joint press was easier.
Old Apr 12, 2010 | 09:43 AM
rbertalotto's Avatar
Are the front axle u-joints plastic bedded like the drive shaft u-joints?
If they are, you need to heat up the metal to melt the plastic to remove them.
Old Apr 12, 2010 | 08:40 PM
pik's Avatar
pik
Axleshaft u-joints are not plastic bedded. Just used lots of penatrating spray.
sootnsmoke
Sep 23, 2012 12:26 PM
ride_a_hd
Mar 18, 2012 01:53 AM
quicksilvr
Mar 17, 2010 11:18 PM
mattyfz450
Mar 27, 2009 08:03 AM
