Front axle stub shaft..... Uh oh
I was working on the truck today trying to get it ready to drive across the continent from southeast to way northwest; you know, oil change, and finally getting around to replacing the front axle hubs and u-joints. Those hubs by the way are a PITA to get off, bent an extension and ruined a few sockets in the process but finally got them off. When trying to pop out the old u-joints after soaking them in PB blast I was able to get half of the caps off to separate the stub shaft from the passenger side axle shaft. When I went to press out the remaining caps of the u-joint I ended up bending the flange on the yoke a little bit
.The u-joint is still in there and hasn't budged ( yes the c-clips are removed).
My next course of action is to use a torch to heat everything up and get it nice and loose.
Finally to my question: can I bend the yoke back out to spec and be fine or am I running a big risk of vibrations and other very bad things? I would normally just replace it but I'm having a hard time finding anything local and I need my truck back up ASAP because I am moving on Friday.
Thanks for the help
-Adam
.The u-joint is still in there and hasn't budged ( yes the c-clips are removed).My next course of action is to use a torch to heat everything up and get it nice and loose.
Thanks for the help
-Adam
they should pop out fairly easy with a press, I bought one on sale at harbour frieght for under $150 bucks, you will make your money back the first time you use it, and with our trucks you will prob. be changing u-joints often.
mbmrang
Aug 18, 2009 11:31 AM
