Front Axle not engaing
Old Oct 2, 2017 | 04:30 PM
Duck Soup's Avatar
Looking for information on how the front axle engages on my 06. My transfer case engages (manual lever) but it doesn't engage the front wheels. Was looking for some sort of vacuum motor device on the axle like my 01 had. Automatic transmission.
Old Oct 2, 2017 | 10:06 PM
MAC702's Avatar
Does it work the same as the 2nd gens? If a dash venting hose loses vacuum, it will affect cruise control and front axle engagement.
I just cut off and capped the vacuum line that ran into the dash, and then all was good again for the important stuff.
Old Oct 2, 2017 | 10:09 PM
ofcmarc's Avatar
There is NO vacuum motor or any other disconnect for the front axle outside of the T-case. When in 2wd, the t-case simply doesn't drive the front driveshaft.
Old Oct 3, 2017 | 10:01 AM
Duck Soup's Avatar
That's what I was afraid of. So the issue must be in the T case. I can hear the case winding up in low but it must not be applying power to the front driveshaft. Thanks for the info.
kxgeorge
Sep 19, 2013 12:24 PM
rustydeeretech
17
May 21, 2011 03:05 PM
case310350
Jun 23, 2010 09:03 PM
adamsmarshall
Nov 10, 2008 10:17 AM
Hawkeye
Apr 29, 2008 10:24 AM
