to flush or not
Old Mar 8, 2010 | 01:06 PM
sotex's Avatar
to flush or not
i have been wating to service trans on o4 thinking a bout swtiching to amsoil but have been told that b-g flushing machine might cause more problems loosing up varnesh and outher contaments. may be best to stay with mopar traney fluid?also have govoner pres solonid to re place 1-2 shifting problem i hav orderd one from perf-automovie trans . wat yal think a bout flushing or just change fluid and filter.
Old Mar 8, 2010 | 01:29 PM
Lost Lake's Avatar
I'm doing mine in two days. Transgo kit and cleaning the original solenoid.
I would not flush the trans. You see all that gunk in your pan? I don't want that flushed back in the trans, I want to drain it out.
Old Mar 8, 2010 | 01:31 PM
Shanajustin's Avatar
no flush.....
no flush.....
Old Mar 8, 2010 | 02:17 PM
05HDRAM's Avatar
There is a big difference between flush and exchange. An exchange is nothing more than pumping your old fluid out and new in - using the trans. pump. Do a search on how to do your own exchange. I did it and will do it again. There is "zero" chance of causing problems unless you let the tranny run dry or forget to hook the return line back up.
Old Mar 8, 2010 | 02:23 PM
DBLR's Avatar
With the exchange do they replace the filter first and then exchange the rest of the fluid? I've always been told and taught that the filter needs to be changed at every service.......
Old Mar 8, 2010 | 03:39 PM
05HDRAM's Avatar
I didn't go into the details, but yes I change my filter when doing it myself. It's cheap insurance. If I was going to a shop, I would ask them to make sure they are doing that.
Old Mar 8, 2010 | 06:18 PM
sotex's Avatar
do it my self
if i disconect retrurn line lit run in nuteral til fluid stream changes . when it dose is that the time to remove pan and replace solenoid and filter re install pan ad fluid run in neturel til fluid runs bright red hook up return line top of traney.?
Old Mar 8, 2010 | 08:29 PM
Spooler's Avatar
Don't do that, if you run everything dry, not good. Depending on the mileage, fluid exchange= "YES", Flush = "NO".
Old Mar 8, 2010 | 08:32 PM
roughstock's Avatar
Yes, do the exchange. Get all the old fluid out. it will run much longer.
We do fluid exchanges on all the trucks at work. and many have 200,000+(many are Gas) on original transmission.
Old Mar 9, 2010 | 05:52 AM
05HDRAM's Avatar
You don't run it dry, you run it till the stream starts to change. That lets you know it is starting to get low in the pan.
Old Mar 9, 2010 | 08:07 AM
sotex's Avatar
how mutch
how mutch fluid will traney hold this i belive 12-14 quarts ? also is valvoline trans fluid ok thankes for all info.
Old Mar 9, 2010 | 08:25 AM
Dr.Dizzle's Avatar
The transmission and components should take 14 quarts. A dry transmission and it's components will hold 18 quarts. Pick up one or two extra just in case. Valvoline ATF+4 is a licensed brand and works for me.
CACalomino
16
Mar 22, 2010 06:35 PM
Sam Turner2
Nov 18, 2008 10:17 AM
grantx5
Jan 5, 2008 06:56 AM
LFD2037
Nov 8, 2006 09:12 PM
Bad Ramer Jamer
13
Oct 20, 2006 12:39 PM
