Fluid substitution for rear end
Old Oct 20, 2010 | 05:20 PM
  #31
mjf6175's Avatar
Below is an exerpt from an outline on the legal battle that occured between Mobil and Castrol oil awhile back. As you will read below, Mobil took Castrol to court over Castrol using dino stock (they were the first to do this) to make a "synthetic". Mobil going to court for the obvious reasons, it was using the more expensive stuff, no dino base. In the end Castrol won the suit. This opened the flood gates of other oil companies following in Castrol's footsreps (including Mobil) since it is cheaper to produce a synthetic starting with a dino base. Read below:
Here's what happened, according to a detailed account published in the trade magazine Lubricants World. Late in 1997, Castrol changed the formula of its Syntec "full synthetic motor oil", eliminating the polyalphaolefins (PAO) base stock (that's the "synthetic" part, which makes up about 70% by volume of what's in the bottle) and replacing it with a "hydroisomerized" petroleum base stock.
Mobil Oil Corporation, maker of Mobil 1, "Worlds Leading Synthetic Motor Oil," said no fair and took its complaint to the National Advertising Division (NAD) of the Council of Better Business Bureaus. NAD often arbitrates between feuding advertisers on their conflicting claims.
The notion behind synthetic motor oils as we've known them is an elegant one. Instead of relying on the cocktail of hydrocarbons contained in crude oil, why not go into the laboratory and build the perfect base stock from scratch, molecule by molecule, and builds it till it gets 10-carbon molecules, then combines three of those to form PAO. The result is a fluid more stable than the usual base oils derived from crude. It keeps flowing at low temperatures. It's more resistant to boiling off, and more resistant to oxidation, which causes thickening with prolonged exposure to high temperatures.
Still, there's more than one road to the point B of improved stability. Petroleum refiners in recent years have learned how to break apart certain undesirable molecules - wax, for example, which causes thickening of oil at low temperatures- and transform them by chemical reaction into helpful molecules. These new hydroisomerized base oils, in the view of some industry participants provided properties similar to PAO's but only cost half as much," Lubricants World reported.
The argument before NAD tiptoed around the obvious- does the consumer get four bucks' worth of value from each quart of synthetic oil?- and plunged straight into deep semantics. Mobil's experts said "synthetic" traditionally meant big molecules built up from small ones. Castrol's side held out for a looser description, defining "synthetic" as "the product of an intended chemical reaction."
What do unbiased sources say? It turns out that the Society of Automotive Engineers (SAE) and the American Petroleum Institute (API) both have technical standards covering motor oils, and both of these organizations in the '90's backed away from their old definitions of "synthetic," leaving lots of room for new interpretations.
In the end, NAD decided that the evidence constitutes a reasonable basis for the claim that Castrol Syntec, as currently formulated, is a synthetic motor oil, said Lubricants World.
RowJ
Oct 14, 2012 08:07 PM
LockedandLoaded
Jan 17, 2008 02:51 PM
doorguy
Jun 8, 2007 06:19 AM
supr
15
Aug 4, 2004 03:33 PM
gdh11
Nov 14, 2003 09:51 AM
