fluid between turbo and manifold
Old Feb 22, 2015 | 08:55 PM
chance hood's Avatar
I'm getting something looks like oil or fuel coming out where my turbo and manifold bolts together it's also coming out where my Pyro is tapped in the manifold I don't know what all options could be taking place any input is greatly appreciated thank you
Old Feb 24, 2015 | 08:44 AM
DragonSlayer's Avatar
Pull the front tube off the turbo and have a look. It should be dry as the desert.
Old Feb 24, 2015 | 04:50 PM
The turbo is dry
Old Feb 24, 2015 | 09:19 PM
BigIron70's Avatar
Cummins Guru
The dark gray liquid commonly termed "diesel slobber" or "slobber" consists of unburned diesel fuel, water, and sometimes crankcase oil which has passed through the combustion chamber, but did not burn. These are materials that did not burn because of cylinder temperatures which are too low to promote complete burning. The lower temperatures occur at start-up until the engine comes up to operating temperature, or when the engine is idled for prolonged periods, which causes the cylinder temperature to lower. Small amounts of crankcase oil sometimes find their way past the piston rings and valve guides in a new engine or in a "cold" engine while idling, and the unburned crankcase oil mixes with the unburned fuel to add to the "slobber." Joint in manifold is designed to prevent manifold breakage due to expansion and contraction during normal cold to hot operating conditions.
That pretty much sums it up.
TireHauler04
22
Oct 11, 2019 04:02 PM
Common
Jun 9, 2008 12:16 PM
wreedCTD
Sep 7, 2007 07:01 AM
cincydiesel
Jun 23, 2007 08:39 PM
