flash for locking out OD while towing?
Torgue converter
Probably worth it (over $200). Here's a link for info - http://www.xtremediesel.com/index.as...OD&ProdID=1667
This is great information. well, this BD power overdrive lockout thing looks interesting. I wonder if it will lock a torque converter on command in third or fourth gear as well? I wouldn't have to do the mystery ground switch then.
Great info, Thanks 2003ram, donnee !
I had the flash for OD lockout done, because I didn't want to add anything "non-stock" onto my truck that Dodge could use as an excuse to void my transmission warranty. It worked great on my 03 (still does- it's my son's truck) and works great on the 05. When they do a flash for the OD lockout, or the "high idle feature" it does not automatically do the "reverse honk recall". I've had them both done, and other things. I made sure they knew, and wrote down not to do the honk recall. If they still do the honk recall, and tell you it goes with the other flashes, they are lying to you.
Flattman
Oct 16, 2007 01:07 PM
CamperAndy
May 18, 2007 12:36 AM
8mpg
Apr 28, 2006 10:08 AM
xp8103
Dec 25, 2005 09:45 AM
04RAM2500
13
Dec 17, 2004 10:02 PM
