First oil sample out . . .
Old Jan 6, 2009 | 06:51 AM
  #31
Foxborough's Avatar
Sounds like the sample was better the normal, great . It will be interesting to see the full report.
Old Jan 6, 2009 | 07:55 AM
  #32
BMH95's Avatar
Ok, here are the stats. Hopefully this will work.
Old Jan 6, 2009 | 08:03 AM
  #33
BMH95's Avatar
I think I'll extend my intervals to 7,500 for a couple of cycles and then test it again. I'm not brave enough to go 10,000 quite yet. In my paranoid mind, it could be that it's doing well because I have always changed the oil at 5,000 miles.
Old Jan 6, 2009 | 08:17 AM
  #34
Hvytrkmech's Avatar
I would go 9000 mi on that oil report without a second thought. If you want you can change the oil filter a 4500 mi then just top off the oil. I would bet at 9k they would say go to 12k. Your engine is holding up well.
Tim
Old Jan 6, 2009 | 08:21 AM
  #35
RowJ's Avatar
Being your first diesel....nothing wrong with working your way up to 10,000 mile changes.
You will get there with the Premium Blue.... based on what I've read in other postings.
Enjoy the process!
I would reduce the 2 qts to 1 qt 2-cycle. Even better if you can get some Biodiesel (B20) and run 5 gal in each tank (1 gal of pure Bio). Was rated best of the lubricity agents tested. I do this and it nets me 3% biodiesel..... good lubricity without hurting mileage.
RJ
ctd4stan
May 5, 2011 10:39 PM
keith1992
Jan 4, 2009 08:37 AM
RDM16CTD
20
May 9, 2006 07:46 AM
marv h.
Feb 19, 2006 07:34 PM
2manydogs
Nov 3, 2003 09:37 AM
