First Cold Snap, 2006 No Start.
Old Oct 9, 2007 | 04:47 PM
rip 112's Avatar
I've been told to cycle the truck more than once before starting on below freezing days. Never had a problem up north.
Old Oct 9, 2007 | 04:57 PM
realsquash's Avatar
I think what you heard was completely normal for a cold start at that temp. Next time it does that just let it run. There is no need to plug it in at 20F.
Andy
Old Oct 9, 2007 | 07:56 PM
D-Roc's Avatar
Originally Posted by Thundercloud
Well it has been in the low 20's here in Durango, Colorado and my truck this morning would not start. First key cycle and the glow plug?/screen? light ( not sure what we have, plugs or screens) came on like normal. When it went out I tried to start it and the engine felt like it was running on 2-3 cylinders. I got scared and turned the ignition off. I waited maybe 5 seconds and tried it again, this time no glow plug?/screen? light and after trying to crank it over once it would not fire. I repeated this process several times (5-6 tries) in a row with the same result, no start of a rough idle like the first cycle and then it quits. I finally got the glow plug?/screen? light to cycle back on and waited for it to go out and she fired up normal. I check for codes and none are present. I am thinking that maybe I should have waited 1-2 minutes before trying to start it again so the computer can reset itself but I am not sure if it would have made a differance. Any suggestions?
Andy
Read his post again, do you really think it is normal?
Old Oct 9, 2007 | 08:45 PM
CD in NM's Avatar
There were seversl guys that had the same starting problems with their 2006 trucks, they DID solve them but I cannot remember what was done or why they had the problems. Some were water in the fuel, some were bio-diesel related, some were the heater grid itself-had to be replaced. They ALL talked about the '3-cylinder' running effect and they did leave them run and it did come up to the right rpm's after a little time of running. It probably is a fluke, as some never had it do it again, call your dealership and ASK about this, may be some memo to solve it or some recommendation for what to test and maybe replace.
My truck has always fired right up, regardless of the cold, it sits outside not in a garage. I have NOT used the block heater, even when temps have gone down to 0. When the temps are at 0, it goes into a higher idle, right around 1K by itself. I could do the high idle mod and have even higher rpm's for warmup, but the 1K does a real good job all by iteslf.
CD
Old Oct 9, 2007 | 08:47 PM
realsquash's Avatar
Yes, I do. I got the same feeling when I started mine at 20F for the first time. "OMG what is happening", it doesn't sound like the gasser I traded in. Then I smelled the diesel, let it sit for 10 seconds, and all was fine. I've had mine for what, 3 winters, going into the 4th, and I only plugged it for a week during that first winter. Never since, all the way down to -13F, unplugged and cold soaked.
Andy
Old Oct 10, 2007 | 12:49 PM
Thundercloud's Avatar
CD
Ya the 3 cylinder running effect to me was too scary to let run like that so I shut it down and started over. I thought that maybe it was a fluke too because it has never done it before and it has not done it again (though only 2 morning start ups). I don't think that is was a normal event by any means, I just want to know if this has happened to others and what was done to fix the problem. I may just call the dealer to see if they have any info on it. I just remember last winter not plugging the truck in that much and it started just fine even in the teens and single digits. When I do plug in, it is on a timer for 3 hours prior to start.
Jumpinjoe
Jan 15, 2012 03:10 PM
beegiedog
Sep 20, 2011 06:37 AM
bullfrog5.9
Jan 3, 2010 05:41 PM
Geico266
Feb 6, 2007 06:47 PM
