Extended Crank????
Old May 6, 2008 | 11:58 PM
WhozNxtLS1's Avatar
Extended Crank????
Hey, it has happened intermittently with no rhyme or reason. Occasionally when I start the truck it seems to crank for 5 seconds or so. normally it's a :crank: :crank: start. When it occurs it's a :crank: :crank::crank: :crank::crank: :crank::crank: :crank: start. I know the batteries are testing out ok which sometimes could be an issue of an extended crank. Truck seems to run with no problem.
Vehicle is a 2005 CTD with 56,000 miles on her. Smarty Jr, stacks, intake.
Also, this occurred after I installed stacks did an oil change and replaced fuel filter. It's been about 900 miles since I did all that and about 400 after the servicing it occurred.
Any help is appreciated. Thank you.
Chris
Old May 7, 2008 | 04:34 AM
Gary Emerald's Avatar
if I don't let my lift pump prime fully, I get extended crank/no start
Old May 7, 2008 | 07:10 PM
chipmonk's Avatar
there is a long crank/cold start re-flash from dodge. other frequent causes are, one or more injectors leaking down and bad pressure relief valve.
Old May 7, 2008 | 08:23 PM
DieselBoy20's Avatar
I have the same problem with mine every once in awhile, it tends to run fine after it does start, but she definately takes awhile sometimes...it drives me crazy. I changed my 2 micron filter on my truck and i thought that helped but 2 weeks later it did it again. Then i thought my lift pump was failing because of my Smarty but it seems to run normal according to my fuel pres. guage. So makes you wonder alright if something serious is slowly happening to the truck, who knows....
Old May 7, 2008 | 08:25 PM
WhozNxtLS1's Avatar
Agreed. I don't know what it could be. Does the Smarty Jr. have that TSP built into it?
Old May 7, 2008 | 08:37 PM
forwardho's Avatar
Try pulling out the Cascade valve and clean it. It is easy to do.
Old May 7, 2008 | 08:39 PM
chipmonk's Avatar
i bet you'd have a good idea of what it could be, if you read my first post.
Old May 7, 2008 | 10:03 PM
ian515's Avatar
I am gonna lean towards injectors.
Old May 7, 2008 | 11:28 PM
WhozNxtLS1's Avatar
I was thinking maybe injectors. I know Dodge won't do anything about it unless they see white smoke on start up. Not having that issue.
Old May 8, 2008 | 04:22 AM
chipmonk's Avatar
why wouldn't dodge do anything about it? if you're still under warranty, you can have them check your injectors, and see if they're leaking down.
Old May 10, 2008 | 11:51 AM
BigIron70's Avatar
Cummins Guru
Long Crank
Read tsb fix for long crank, manual transmission vehicle.
Old May 10, 2008 | 01:20 PM
D-Roc's Avatar
X2...happened with mine.
Old May 10, 2008 | 02:21 PM
ian515's Avatar
I believe dodge would have to do something about it, if you are still under warranty...but getting them to do it is another story. thats kinda why I am glad I am not under warranty, I know I have to pay, but if I need it done, it gets done (of course I dont take it to dodge).
Old May 10, 2008 | 03:36 PM
chipmonk's Avatar
it's just that these injectors are sooooooo expensive!
Old May 10, 2008 | 05:47 PM
ian515's Avatar
indeed they are. but aftermarket is waaaaaaaaaay cheaper than stockers.
