Extended Crank????
Hey, it has happened intermittently with no rhyme or reason. Occasionally when I start the truck it seems to crank for 5 seconds or so. normally it's a :crank: :crank: start. When it occurs it's a :crank: :crank::crank: :crank::crank: :crank::crank: :crank: start. I know the batteries are testing out ok which sometimes could be an issue of an extended crank. Truck seems to run with no problem.
Vehicle is a 2005 CTD with 56,000 miles on her. Smarty Jr, stacks, intake. Also, this occurred after I installed stacks did an oil change and replaced fuel filter. It's been about 900 miles since I did all that and about 400 after the servicing it occurred. Any help is appreciated. Thank you. Chris |
if I don't let my lift pump prime fully, I get extended crank/no start
there is a long crank/cold start re-flash from dodge. other frequent causes are, one or more injectors leaking down and bad pressure relief valve.
I have the same problem with mine every once in awhile, it tends to run fine after it does start, but she definately takes awhile sometimes...it drives me crazy. I changed my 2 micron filter on my truck and i thought that helped but 2 weeks later it did it again. Then i thought my lift pump was failing because of my Smarty but it seems to run normal according to my fuel pres. guage. So makes you wonder alright if something serious is slowly happening to the truck, who knows....
Agreed. I don't know what it could be. Does the Smarty Jr. have that TSP built into it?
Try pulling out the Cascade valve and clean it. It is easy to do.
Originally Posted by WhozNxtLS1
(Post 2073848)
I am gonna lean towards injectors.
I was thinking maybe injectors. I know Dodge won't do anything about it unless they see white smoke on start up. Not having that issue.
(Post 2074124)
Long Crank
Read tsb fix for long crank, manual transmission vehicle.
Originally Posted by ian515
(Post 2074011)
I believe dodge would have to do something about it, if you are still under warranty...but getting them to do it is another story. thats kinda why I am glad I am not under warranty, I know I have to pay, but if I need it done, it gets done (of course I dont take it to dodge).
(Post 2077309)
Originally Posted by chipmonk
(Post 2077353)
it's just that these injectors are sooooooo expensive!
