Engine won't start
Old Aug 12, 2005 | 06:34 PM
bigjon440's Avatar
Engine won't start
I have my good friend working on my truck. He has removed the cylinder head, and placed it back on. He believes there is still some air trapped in the fuel system. How does one go about removing the air from the fuel system? I am posting this since he is still attempting to get the truck running. Any suggestions would be appreciated!
Truck in question is a 04 2500 Laramie SLT 4X4, everything is stock
Old Aug 12, 2005 | 06:52 PM
P.J's Avatar
P.J
You will need to fill in your signature in order for us to help you i.e what year and model truck.
Welcome to DTR.
Old Aug 12, 2005 | 09:56 PM
bigjon440's Avatar
Bump!
I still need your ideas!
Old Aug 12, 2005 | 10:25 PM
bulabula's Avatar
Welcome.
I must admit wondering why the head of an all stock '04 CTD has been taken off and it's not being done under warranty - but thats me. Has all the makings of a good sea-story I bet.
I'm not a Cummins mechanic, but when changing fuel filters on the 3rd gens, all we need to do is cycle the key a couple of times to pressure up the system; and we don't have to mess with loosening banjo bolts like the older models require.
Again, welcome aboard.
Old Aug 13, 2005 | 08:52 AM
nickleinonen's Avatar
crank it until it catches... DO NOT even think about cracking any of the high pressure lines while cranking or engine running... that is asking for a hospital trip if you do that... are all the sensors hooked back up??? if he had a crank sensor or cam sensor unplugged, maybe he forgot to reattach it???
Old Aug 15, 2005 | 11:33 AM
bigblock2stroke's Avatar
There would be an active fault code for any sensor not being plugged in. Do not crank the engine for more than 5-7 seconds or you will be changing that too. If you bump the starter the lift pump should run for 20 seconds. You should only have to do this around 3 times. You do not have to bleed any part of the fuel system in the 3rd Gen engines as stated above.
Air in the fuel lines means he's buying time because he doesn't know why it won't start.
Subliminal
Dec 15, 2010 04:35 PM
ado2b1
Dec 16, 2008 03:19 PM
Machinos
Mar 16, 2008 01:34 AM
