Engine Stumbled Hard This Morning
Old Jan 18, 2016 | 08:16 AM
06RAM2500's Avatar
Went to start it as usual, and it acted like it was running on 3 cylinders, then all 6 after a few seconds.
Old Jan 18, 2016 | 07:54 PM
Equalizer 2's Avatar
How cold was it?
Seems I recall hearing/reading that in the extreme cold they will sound that way, because they are running that way IIRC.
I will see if my google foo will work.
On Edit: Found a post on the cumminsforum where a guy said that at -25 his made a lot of noise and smoked.
And this from dodgeram.org;
The Cummins B will reliably start at temperatures to -20 degrees F without the block heater, but the engine is much happier if the block heater is used. It may take several manifold heat/start cycles before the engine fires and continues to run. Expect a large smoke cloud, engine and accessory whine, knocking, and vibration until things warm.
HOHN
May 16, 2008 10:04 AM
fbx22
0
Feb 25, 2007 12:07 PM
Luke S
33
Oct 14, 2006 11:03 AM
Marine
Dec 6, 2003 07:06 PM
