On highway, truck stumbled and died.
Old Dec 5, 2003 | 03:47 PM
Marine's Avatar
Veteran: Marine Corp
On my way to MT last week, truck stumbled and died. I turned the key off and back on to hit the lift pump. Just a straining noise coming from the pump. Then I hit it with the flashlight and it started humming right away. bled the air from the filter canister and the truck fired right up. Weather was snowing at about 32 deg. air temp, at night. Could it have frozen up? I did change the sender in the tank a few weeks earlier- could it have been a bit of dirt clogged the vane in the lift pump? This was about 1000 miles ago and temp has been colder since then a couple of times. I have been using Power Service at every fill up. Oh yeah...now I have code 0230-Transfer pump Circuit Out Of Range
What do you think?
Mike
Old Dec 5, 2003 | 10:50 PM
J BODY's Avatar
Re:On highway, truck stumbled and died.
It's possible that the lift pump motor is giving up on you. That code will set if the circuit goes open, or high resisitance (corroded connection).
Old Dec 6, 2003 | 11:37 AM
BigK's Avatar
Mike, stop by the next Cummins shop and get a spare pump. Be sure you carry the tools necessary to change it out.
Just in case.
Old Dec 6, 2003 | 02:07 PM
Marine's Avatar
I might have to do that.
Mike
Old Dec 6, 2003 | 07:06 PM
J BODY's Avatar
;DI work on the things and have a lift pump under my rear seat if that tells you anything.
rip 112
38
Jan 9, 2012 07:14 AM
Txwelder
Nov 22, 2009 04:27 PM
Fergavs
Aug 24, 2007 03:43 PM
Kman9090
Aug 7, 2007 10:35 AM
Luke S
33
Oct 14, 2006 11:03 AM
