Engine shake at shutdown.
Old Apr 18, 2006 | 04:39 PM
RYANGRAPHITE600's Avatar
Will the engine shake more violently the more miles you have on it, and the more broken in it is? Thats one thing I love about my cummins, that shake!
Old Apr 18, 2006 | 05:55 PM
boostjunkie1's Avatar
shake?
UH- - - - Really depends on when you shut the truck down during use. I know that giving it a little throttle right before I turn the key to the off position it makes the shake less noticable!
Old Apr 18, 2006 | 05:56 PM
06inferno's Avatar
not sure about more shake but i have a 06 6sp and when i have the clutch engaged and turn the truck off it doesnt shake as much as it does with the out?
Old Apr 19, 2006 | 02:13 PM
WACTD's Avatar
If by "clutch engaged" you mean "the pedal is pushed down", then technically the clutch is DISengaged because the transmission is not connected to the engine.
I agree that when the clutch pedal is pushed in during shutdown (DISengaged) there is less overall shaking. There's also a discussion on this site that holds it's better to have the clutch disengaged (pedal pushed down) during engine shutdown because it's easier on the clutch/transmission due to torque spikes. Might be more important with the 2006 dual-mass flywheel, I'm not sure.
ric o'shea
Mar 24, 2007 10:50 PM
robox
Sep 9, 2005 06:48 PM
turbo_2500
Aug 6, 2005 07:41 PM
Lightman
14
Oct 29, 2003 05:53 PM
