Loud Klunk and Shake when turning off engine
Old Sep 9, 2005 | 04:22 AM
robox's Avatar
When I shut the engine down, there is a loud klunk sound and the whole truck shakes once. The severity of this symptom varies quite a lot. It obviously has something to do with the engine quickly going from a state of turning to a state of not turning, but.... is it something I need to worry about? Is it normal?
Thanks,
CR
Old Sep 9, 2005 | 05:06 AM
A-Poc's Avatar
Normal... The belt chirp and shake is a common thing on the first gens
Old Sep 9, 2005 | 06:04 AM
JD730's Avatar
The klunk makes it sound like loose motor and/or trans mount. The shake is normal.
Old Sep 9, 2005 | 06:32 AM
csramsey640's Avatar
...and if you had a broken mount, would seem worse than it is
Old Sep 9, 2005 | 03:12 PM
JD and CS are right on, it sounds like a loose or broken motor mount. Tighten everything before you go throwing parts at it, the Cummins will shake pretty much everything on the truck loose at some point.
Old Sep 9, 2005 | 06:48 PM
ChrisLib's Avatar
Even overdrive solenoids .
And i do believe the good Pastor put it best by calling the old "wet dog" shake
jeremy judge
Mar 23, 2010 09:38 AM
bishkoff
23
Mar 5, 2010 03:57 PM
ric o'shea
Mar 24, 2007 10:50 PM
nitis
14
Aug 30, 2006 07:13 PM
silverram323
Oct 10, 2003 12:19 AM
