engine monitor??
Is there a product that i can use to just monitor EGT,Boost,Trans temp?
Plug into computer
I have the 04.5 600HO
i dont want to put in gauges
AND
I dont want to void warranty!!!( i have 6 years left)
Just would like to monitor these functions when towing my travel trailer!!
Why doesnt dodge put a stock tranny temp in the cluster??
Thanks
Plug into computer
AND
Thanks
Originally posted by STATELINE
bully dogs outlook monitor will take care of boost & pyro, but not trans temp
I have an X-Monitor on my 04.5. You can see a picture of it in my gallery. The trany temp is just clipped to a wire on the ecm. the boost tubing is connected to a replacment bolt on the side of the engine where the air goes in after it goes through the innercooler. The thermocuple for the egt has to be mounted either in the exhaust manifold before the turbo or in the exhaust pipe just after the turbo. It requires drilling and tapping.
Bill
Bill
Bill
Bill
i also say pre turbo is better, but if you are real scared about warrenty denial, go post but as close to the turbine outlet... lots of high temp antiseize on the threads so you can remove it later... with no fueling mods, post will be fine... when the fueling mods start, pre turbo would be a very wise idea
dzl_damon
Feb 24, 2008 03:10 PM
G-NOTE
Nov 15, 2007 08:30 AM
nitis
Feb 26, 2007 07:38 PM
04.5HO600
Jun 27, 2005 09:28 PM
