Engine Light comes on when temperature drops below 32F
Old Nov 7, 2008 | 03:00 PM
cdn3500's Avatar
Hello,
I bought my 2006 Dodge Quad Cab 3500 last fall, and my engine light came on and stayed for the duration of the winter. I had it diagnosed, and nothing came up. The techs would reset it, and a day or two later, it would come back on.
Come Spring, once the air temperature warmed, the engine light went away. Now that it is fall again, and the air temp has dropped below 32F, the light is coming back on. Thoughts?
Thanks.
Old Nov 7, 2008 | 03:13 PM
CatDiesel_762's Avatar
Have you checked this TSB out: (http://dodgeram.info/tsb/2007/18-001-07.htm).
Shawn
MikeyB's Avatar
Any codes? Turn the ignition ON/OFF/ON three times to get the codes to appear in the odometer display.
MikeyB
Old Nov 7, 2008 | 09:57 PM
Mikey, I do not think the on off three times work with the cdn3500 (06's) due to the CAN Bus programing. The 05 and older will be able to read the codes.
CDN3500 will have to go get a cheap code reader or go and ask the parts store to borrow one to find out codes.
I am thinking he has a failed sensor either near the battery or the air temp.
Shawn
Old Nov 8, 2008 | 07:12 AM
MikeyB's Avatar
Shawn
Really? Thought the key trick worked all the way to the '07 models.
Yep, sounds like the battery temp, AIT or the MAP.
MikeyB
Old Nov 8, 2008 | 08:41 PM
CoolumConst's Avatar
Check the two relays by the passenger side battery. Make sure they are connected. I had a code when one of they came disconnected. They are for the grid heater.
Old Nov 22, 2008 | 09:50 PM
cdn3500's Avatar
Temperature sensitive
Yep, today when it warmed up above 32F, the light went off. I keep it plugged in when it is cold, but regardless of that, anything below 32f the light still comes on.
Old Nov 23, 2008 | 08:11 AM
jncornett's Avatar
I dont know if this will help but here goes..... do you keep your truk in a shop or garage?? my truck is a 05 if its been inside for a while and the the temp is cold outside it will throw a code for temperature rationality...it starts and sees warm air inside then goes outside to and reads the air temp and doesnt like it ... it seems the difference between our trucks is if mine stays outside and starts at that temp it doesnt throw a code or turn on the check engine light like yours does..
again just throwing something out there
Old Nov 23, 2008 | 08:25 AM
Old Hat's Avatar
my 06 did the same thing last year, I just kept driving it and it went off..
Old Nov 23, 2008 | 08:51 AM
Hvytrkmech's Avatar
The rational code is very common in the cold weather. This is the tsb on it.
http://www.dodgeram.info/tsb/2006/18-005-06b.htm
Yes you can check for codes with the 3 key turn procedure up to 07.
Tim
Stude4x4
Mar 30, 2013 07:03 PM
hconstantino
May 3, 2010 12:15 PM
zking
14
Feb 24, 2009 06:41 AM
Chesapeake
Nov 29, 2006 02:44 PM
