engine light on
Old Nov 26, 2009 | 12:25 PM
walterh's Avatar
engine light on
engine light came on and found code p0607 ecm internal failure.is this a dealer item repair. tried to reset code with no luck. any help on this much appreciated. thanks
Old Nov 26, 2009 | 04:17 PM
BigIron70's Avatar
Cummins Guru
Symptom:
P0607-ECM INTERNAL FAILURE
When Monitored and Set Condition:
When Monitored: With the key on or engine running.
Set Condition: ECM had detected internal failures.
POSSIBLE CAUSES
ECM
TEST ACTION APPLICABILITY
1 Turn the ignition on.
NOTE: This DTC is caused by an internal Engine Control Module failure.
Repairs are not possible to the ECM.
Is the DTC P0606 set?
ENGINE- 5.9L
CUMMINS 24V
DIESEL
Yes ! Replace and program the ECM in accordance with the Service
Information.
Old Nov 27, 2009 | 08:54 AM
walterh's Avatar
how does one check that .is a scaner tool required to see if p0606 is set . im guessing this is a dealer item repair.
Old Nov 27, 2009 | 07:31 PM
1985cucv's Avatar
fill out your signature so we knwo what truck you have its on the top header in the user cp
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
99gt
Mar 24, 2010 09:13 PM
choppers555
Oct 16, 2007 12:29 PM
Stevenc
Dec 28, 2004 08:29 PM
