Engine Knock?
Old Jan 28, 2004 | 08:32 AM
sawboywv1's Avatar
Engine Knock?
While plowing snow last night I was up against a hill with the window rolled down. From a slow start I could hear a very loud KNOCK similar to a rod knock. I've never heard that before. As soon I get going it is gone. Also cannot hear it with the window up or just revving it. Maybe it is all the snow packed up under the truck? I did put some fuel additive in the other day...PowerService, think that caused it? I let the Diesel tech at work listen to it and he says it sounds SWEET and tight to him. ****.. to be concerned or not?
Old Jan 28, 2004 | 08:41 AM
mymaur's Avatar
THey will give a pretty good sound, similar to a knock when under a heavy load at idle or when just applying a small amount of power.
Old Jan 28, 2004 | 01:55 PM
spots's Avatar
Be concerned if the knock doesn't go away when you rev it up. Different fuel quality can make them more noisy off idle.
Old Jan 29, 2004 | 11:33 AM
GotCummins?'s Avatar
My 03 did the same thing, when letting out clutch in 2nd gear, engine would make a LOUD "clack, clack, clack" noise then go away at about 1000 rpms or so. I stopped buying fuel from the local "mart" at started buying from truck stop down the road. Pay 15 cents more per gallon , but NO MORE CLACK, and MPG went from 18 to about 21-22. Also I use FleetGaurd FleetTech fuel conditioner every 4 th tank. Recommended by Rocky Mountain Cummins.
Old Jan 29, 2004 | 12:46 PM
sawboywv1's Avatar
THANKS, I will try fuel from another station.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
