Engine Identification
Welcome aboard MDP.
I really can't help you with the motor type other then it should be listed on the side of your valve cover on the motor. I think it will either say 305 or 325 for hp.
Go to the CP section and fill in info about your truck and stuff. It will help others help you in the future.
Any way, welcome.
Any way, welcome.
The 10th digit is a 4, so that means the truck is an 04. With a C in the 8th digit, it's either a 600 (325/600) or the HO (305/555). It's not a SO, but you'll need to post more info.
Check the door jamb for the build date, if you can't see the sticker on the side of the engine as was suggested.
Thanks
You have the High output 325/600 the c in the 8th postion is the 600 series. When going to part stores they will ask you what motor you have. You have the C motor. But just look at the door 1/04 or after is the 325/600
ptextreme
Jun 4, 2008 11:15 PM
kennymac131
Dec 11, 2006 06:50 PM
ataboy9026
Oct 2, 2005 08:28 PM
