engine hours
BTW did you notice any difference with your rokktech? Thinking of getting one, just dont know yet..
"This crankshaft sensor perfectly replaces the stock Cummins sensor, allowing for adjustable timing without codes or a voided warranty.
Adjustable up to 2 degrees, in 0.1 degree increments, it improves mileage, increases torque and power, reduces exhaust temperature, and reduces greenhouse gases and smoke (even with larger injectors).
Undetectable, will pass emissions testing. Includes instructions."
The mpg gain would be what I would be looking for. My commute is 60mi/day. Course any extra power or tq gains would be quite welcomed when i'm towing. Thanks for the reply, I might give it a shot. Also I just noticed you run Silent Armour tires, what do you think of them??
What are the other weird numbers that show up along with the hour's, codes? I looked today and had about 3 or 4 different numbers flashing by, I only have 3,700 miles on, and the engine light has never come on, so I wouldn't think they would be code's but I could be wrong.
"S or a 5 35" I am assuming this was the hours.
"= 315" the two lines were actually a litlle farther apart but this is the closest key i could find to show them.
" [ 542" the "[" actually looked more like a "C" but once again closest key I could find to show it.
this is on a 2007 2500 with 5.9 and auto trans. Thanks.
