Electric Fan Clutch wiring diagram
Old Aug 27, 2005 | 02:09 PM
ricknsharon's Avatar
Please help.
Is there anyone with a factory manual for a 2003 or newer Dodge that would research the electric fan clutch operation and wiring of same? I am installing one on my '99 Cummins in a pusher motorhome configuration and I need to understand the electric controls of the fan clutch. I know it'll take some electronics to do it, maybe even a PWM computer output but I can handle that.
I have checked the five wires from the clutch and the red & green appear to be a tach generator output that provides an AC Mv signal to the computer for the amount of clutch slippage. I get about 6 Mv AC when given a good spin and appear to be linear to the RPM.
But I'm stumped with the other three wires, they have no continuity between them and do not output a voltage, AC or DC, when the clutch is spun. However, I do get readings when my multi-meter is set to diode test so the leads may go to a transistor, maybe to monitor radiator airflow temperature.
So what I need to know is how can I operate this fan clutch? There has to be a way for me to be able to engage or disengage it with an electric signal.
Please help.
Rick
Old Aug 27, 2005 | 02:26 PM
handymantim's Avatar
I'm going to look in my 2004 manual but while I'm looking you can go to:
http://www.hemitruckclub.com/03DRM.pdf for the 2003 manual or
http://www.hemitruckclub.com/04manual/ for the 2004 manual.
Old Aug 27, 2005 | 02:34 PM
Go to that 2004 shop manual page, 8W-30-54 and you'll find the info you want.
Old Aug 27, 2005 | 04:52 PM
That's what I was looking for. Thank you very much.
I am still missing the operation details so if anybody has first hand knowledge of how to electrically engage this fan clutch, please help.
Thanks,
Rick
Old Aug 28, 2005 | 11:42 PM
Superduty's Avatar
Welcome to the fun of trying to do something with the electronics on a Cummins. The wiring diagram shows how to connect it, but that is about all you'll get. The best way would be to put an oscilloscope on an engine and see what goes to the fan when someone commands it to "high" with a scan tool.
I'd do that for you, but I am really busy these days and I don't have a scan tool.
Old Dec 27, 2008 | 05:47 PM
4.8t's Avatar
i need help with this also, well kinda. my clutch fan will not engage with the a/c on and it causes the a/c line pressures to sky rocket. the link do not work any more does anybody have an updated link?
BRUISER
Sep 29, 2024 12:07 PM
Diesel Girl
18
Oct 6, 2013 03:03 PM
schamran
Jul 26, 2013 09:30 AM
92smokin blacky
Oct 7, 2011 03:08 PM
