ECM connector pins
Old Nov 17, 2010 | 07:01 PM
TOBC's Avatar
ECM connector pins
Does anyone know if the connector pins on a 06 cummins engine ECM are the deutch style, I'm going to enable high idle, i looked at a pic someone posted of the connector kit and it looks to be a duetch pin which we use at work so I could just make my own if thats the case. Thanks for any info.
Old Nov 17, 2010 | 07:56 PM
Pooter's Avatar
this is what you need, $12-14 from cummins, ive been trying to find one cheaper, but this is what you need, PIN 22 on the ecm plug
Old Nov 17, 2010 | 11:46 PM
TOBC's Avatar
Thanks for the info, I'll check with cummins and let you know if it is a deutch style. If it is the pin is worth about a 1$. But the special pliers we have to crimp them are about 400$. If your carefull you can use normal wiring pliers though.
Old Nov 18, 2010 | 05:42 PM
PoorMansCat's Avatar
Yep.. it Duetch.. YES, the Cat ones are the same.. ( if thats what you were asking)
Old Nov 18, 2010 | 06:36 PM
Pooter's Avatar
Do you have a PN on a CAT pigtail like above? I dont have the special crimpers for the end, but I can just pop in that pigtail and ground it just fine.
Old Nov 24, 2010 | 06:51 PM
TOBC's Avatar
Sorry I don't have a cat number as they are in the deutch kit. Its the small size of the deutch terminals. If you can get the pin you can crimp them with normal wiring pliers if your carefull, I've done it in the past when I didn't have the proper pliers. Will be installing it tonight, I will let you kow how it goes.
Old Nov 24, 2010 | 07:12 PM
Your local Mac tools dealer has a set of pliers that will also form this crimp.. they are about $30.00
Old Nov 24, 2010 | 08:50 PM
TOBC's Avatar
Put the pin in #22 rear ecm connector and took it to ground, it doesn't work. I will have to get Dodge to program the PTO enable.
Old Nov 24, 2010 | 09:30 PM
Pooter's Avatar
Borrow a buddies smarty or bully dog, both enable the high idle(on the ecm side of things) grounding the pin just enables it to be used once turned on in the ecm.
Old Nov 25, 2010 | 01:26 AM
DaveB.inVa's Avatar
Is there anywhere you can order the item above online?
Old Nov 25, 2010 | 07:21 AM
MikeyB's Avatar
If someone can give me the pin measurements I might be able to cross reference from a cheaper source, like Mouser or Digi-Key.
MikeyB
Old Nov 25, 2010 | 07:38 PM
TOBC's Avatar
Had to get Dodge to enable it for 30.00$ but it works, idles it up to 1500RPM with cruise function. I will get the CAT part number for the pin at work and post it.
Old Nov 25, 2010 | 08:55 PM
Pooter's Avatar
Awesome! Thanks
Im assuming its quite a bit cheaper than the cummins one right?
Old Nov 27, 2010 | 07:34 PM
krh's Avatar
krh
lol, probably more expensive knowing cat. But one pin can generally go missing out of the film can.
Old Nov 30, 2010 | 10:04 AM
ripping r's Avatar
has anybody found a cat part number. i have a cat dealer buy the house but no cummins dealer. i tried to get the dodge dealer to make me one. they said no.
ratat98
Sep 18, 2016 07:34 PM
Abbey109
May 2, 2014 11:37 PM
madhat
Jan 8, 2010 09:21 PM
Fisherguy
Jun 10, 2007 01:08 AM
Ohio Joe
Jul 12, 2004 12:13 PM
