ecm codes
Old May 2, 2006 | 11:14 PM
stlsparky's Avatar
ecm codes
I had my check engine light come on and the the truck started to idle rough pumped the go pedal and it cleared out. 4 codes came up injectors low voltage group b came up twice, and torque convertor came up twice. I have had no problems since and it runs fine now. Should I take it in or wait for a problem. I will have to make it stock again and clear the ecm so there are no footprints from edge or bullydog, then get a new airbox because mine is swiss cheesed also cat is flow through will they be able to tell? advice?
Old May 3, 2006 | 09:45 PM
stlsparky's Avatar
anyone? bump
Old May 3, 2006 | 09:58 PM
djbikeman's Avatar
Originally Posted by stlsparky
anyone? bump
The first thing you should do is call Edge. I had codes thrown once on my 04.5. I called Edge, the sent me a new Juice and all was well again. I didn't have to ask, they offered this to me. I did go into Autozone and get the codes cleared right after the check engine light came on. I believe I had the same Injector Low Voltage codes.
If you do need to take it back to the dealer, I wouldn't worry about the air filter and exhaust.
You definitely need to get the Juice/Attitude off, and then figure out how to explain the pyro probe. I had a bullet mounted EGT guage that I could install in a few minutes. When I pulled the Juice I would velcro that to the steering column. The only thing I didn't connect was the guage lighting.
Old May 3, 2006 | 11:51 PM
inline6power's Avatar
[QUOTE=stlsparky]I had my check engine light come on and the the truck started to idle rough pumped the go pedal and it cleared out. 4 codes came up injectors low voltage group b came up twice, and torque convertor came up twice. I have had no problems since and it runs fine now. Should I take it in or wait for a problem. I will have to make it stock again and clear the ecm so there are no footprints from edge or bullydog, then get a new airbox because mine is swiss cheesed also cat is flow through will they be able to tell? advice?[/QUOTE
my dad has a 04.5 and that low voltage code came up 3 times. after that the lift pump went out. put a pusher pump on it and never had any more probs.
ratat98
Sep 18, 2016 07:34 PM
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
Ohio Joe
Jul 12, 2004 12:13 PM
