dually wheel spacer
Old Mar 2, 2008 | 11:27 AM
tt433's Avatar
dually wheel spacer
does anyone know what the smallest wheel spacer you can run on 285/75/17 toyo tires? I was thinking of 3/8 or 1/2 " but some one told me you cant get a full lug on the 1/2" spacer.
Old Mar 2, 2008 | 10:56 PM
bruce03's Avatar
With the stock studs I think 3/8" might be the max but I don't know if that will give you enough space between the tires. Most people I think run a 2" spacer or you could replace the studs with longer ones.
Old Mar 3, 2008 | 08:00 AM
BgBlkTrk's Avatar
I am thinking 3/8" would be the bare minimum, I just went with the 2" ones in case I want to upgrade to 35"-37" later, plus you don't have to worry about trimming the studs or not having enough lug.
Old Mar 3, 2008 | 09:21 AM
Rollin' Smoke's Avatar
i did the same thing
Old Mar 3, 2008 | 09:34 AM
nelrod's Avatar
I am going with 1.5 inches just to keep tires from sticking out extra half inch, beyond wh. wells. ( I know, its, not much). ---if they even sell that size, I'm kind of afraid of the aluminum ones, looking at Arrowcraft.com all steel, no aluminum used.
Old Mar 3, 2008 | 09:45 AM
the guy from wheeladapter.com will build you any size you want. they are steel and good quality. give him a call see what he says
Old Mar 3, 2008 | 11:32 AM
SpinEmNSmokeEm's Avatar
i have gotten 2, 2" spacers from wheeladapter.com and had absolutly no troubles from them. I have heard from a 4 wheel drive shop that some other brands didn't fit correctly or cracked and just didn't hold up. I don't believe that you can get anything less than 2" without having to trim the studs. What is an extra 1/2" anyway, the mud still flies everywhere. The ones I just bought for my 07 cost $375 I believe delivered.
Old Mar 4, 2008 | 10:15 PM
nelrod's Avatar
Thanks rollin smoke, that is just what I will do.
Old Mar 8, 2008 | 01:59 AM
nelrod's Avatar
You are right Sip, I am going to get the 2 inch. Not worth having to cut the wheel studs off for half inch.
Old Jun 11, 2008 | 09:35 PM
ozpall's Avatar
bringing this back from the dead,
anybody running this spacers from ebay? i really don't feel like spending 300 from wheeladapter or whoever.
thx
http://cgi.ebay.com/ebaymotors/WHEEL...mZ120271629219
Old Jun 12, 2008 | 11:00 PM
pwknapp's Avatar
I bought my 2" from performance tire in Denver. I think they were @ 95 ea. Very nice quality tough pcs. JM.02
Old Jun 13, 2008 | 12:25 PM
ozpall's Avatar
each spacer was 95 bucks?
Old Jun 13, 2008 | 04:51 PM
hcsmith's Avatar
I run a 2 inch on my 03 and have for over a 100,000 miles with no problems pulling or anything. There are studs built into my spacers and the holes for the sock studs are counter sunk. Think I got them from performance wheel, also I an runnin 285s currently in the past though I ran 35x12.50 no tire rub even loaded
Old Jun 13, 2008 | 05:12 PM
ozpall's Avatar
what is the biggest tire i can run without any spacers??
Bumble76
May 28, 2012 04:47 PM
Undertaker
0
Mar 3, 2010 01:21 PM
06dodgedrw
Jan 5, 2010 07:55 PM
0524VHO
Jun 12, 2008 10:49 AM
Hired Gun
33
Dec 3, 2004 10:52 PM
