drive train upgrade for mileage
Old Apr 20, 2006 | 08:29 PM
Red Ram's Avatar
Question drive train upgrade for mileage
Any suggestions for gear swaps to lower rpm & get better cruising mileage? I don't need fast starts, just want to drive my truck a little more. 4 speed auto diesel front axle 9.25/ rear axle 11.50/ ratio 3.73. Can you even do this without harming the drive train?
Old Apr 20, 2006 | 08:41 PM
bbhzx12's Avatar
AAM is supposed to be releasing a 3:42 gearset, or get a gear vendors gear splitter.
Old Apr 21, 2006 | 03:07 AM
TexasCTD's Avatar
http://www.gearvendors.com/index.html
Maybe this is an option.
Old Apr 21, 2006 | 06:27 AM
white Lightning's Avatar
Dropping the RPM's too low is going to do you no good...if you go to low you will be cruising out of the power band of this motor...which will make it work harder....therefore your mileage will be worse...its has been brought up on here before...you can lower it some but the splitter is too much....people i know that did it got lower RPM's and lower or the same mileage.....
Lary Ellis (Top)
55
Nov 8, 2012 10:22 PM
covered wagon
Feb 18, 2006 05:35 PM
mslipac
Jan 31, 2005 06:41 PM
Tiara3100
Dec 28, 2004 06:50 AM
AKDSLDOG
Apr 6, 2003 08:27 AM
