does MAP sensor read absolute pressure?
Old Oct 4, 2011 | 11:44 PM
  #46
1buck4me's Avatar
so as long as I stay under 40 psi I should be ok. thank you. I really did not want to spend money on that right now. Also it will not hurt it when I tow?
Old Oct 5, 2011 | 05:48 AM
  #47
AH64ID's Avatar
I would try to limit your time above 35 psi, but many have taken them to 40 without issue.
Towing it will produce higher drive pressure, but nothing that will do more than limit efficiency under 35 psi of boost.
The Smarty Jr doesn't use the WG at all, and lots of people running around with it turned off and not having issues.
Old Sep 14, 2012 | 12:59 PM
  #48
taggmann's Avatar
I have an 05. it is throwing both the p0111 and the p0236. my cheapie reader has live data at 36.98psi map and -40 f not running , what does that mean? short in wire harness or the map iat sensor?
Old Sep 14, 2012 | 01:34 PM
  #49
AH64ID's Avatar
The P0111 points to a bad IAT sensor (pre-turbo), and the P0236 points to a bad MAP sensor (intake manifold). I would check the connections on both (do you have a module, like Edge?) and replace the MAP first.
Old Sep 14, 2012 | 03:12 PM
  #50
taggmann's Avatar
i have a cheap scanner but it lets me check and clear codes and read live data. since it is reading 75.3 inhg of pressure and -40f i am wondering if it is shorted? it instantly shows the codes after i clear them
PCarnathan
Jun 2, 2020 12:52 AM
Redlinear
Feb 14, 2013 01:10 PM
kandgo
Jul 23, 2012 06:49 PM
VikingDiesel
43
Oct 23, 2006 08:41 PM
D.Wiggs
161
Oct 17, 2006 02:37 PM
