Does anyone know?
Old Feb 20, 2008 | 11:24 AM
elirandolph's Avatar
Does anyone know?
How are the front axle shafts retained? In order to pull the axle shafts out do you have to open up the diff and remove a retainer clip? Or is it retained by the castle nut on the hub assembly. Service manual says to remove axle shaft and thats it. Am I missing something?
TIA
Eli
Old Feb 20, 2008 | 03:10 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
There are no internal clips. Just the nut on the axle through the hub.
Chris
Old Feb 20, 2008 | 03:28 PM
Chris
Cool! thats what I was hoping for.
Old Feb 20, 2008 | 06:59 PM
http://www.pavementsucks.com/tech/balljoint.php
Can someone explain to me what CAD is that is referenced in the write up link above (first paragraph). I know this is on a Dana axle, but I was wondering if I have to do this with the AAM axle. Once I have the hub off I can just pull the axles out right? Is there a need to lock it in 4x4 before I start?
TIA
ELI
Old Feb 20, 2008 | 07:35 PM
rams-n-hogs's Avatar
TIA
ELI
CAD is Central Axle Disconnect. The AAM axles don't have it. Once the hub is off, you can just pull the axle out. No need to lock it in 4x4.
Old Feb 20, 2008 | 08:26 PM
Thanks for the Help.
morkable
ABDTR #5
16
Sep 10, 2009 11:41 PM
jeffs07mega
Feb 24, 2009 02:47 AM
drewallen42
Apr 14, 2007 01:07 PM
moparman2
13
Oct 13, 2003 08:04 PM
westcoaster
Sep 22, 2003 09:15 PM
