Do Ford Diesels LUG better than our 5.9s?
Old Aug 7, 2009 | 01:31 PM
dodgeramit1's Avatar
Originally Posted by Flopster843
The 6.7 is by far more powerful off idle and at low speed than either of those engines. I've never towed anything heavy with the 5.9 but I'm pretty sure it is the same way as the 6.7.
Yeah but when you get a 6.7 going good, they enter the regen process and your egts go sky high and you have to ease off the throttle.(personal experience.)Our ford 6.0 service truck has nothing at low rpm. towing uphill with one is a nightmare. I love my 5.9. I wouldnt have a ford if you gave me a million dollers and a ride on a rocketship to take one. You need totalk some sense into your friend, or send him over this way and we'll greet him with a cloud of blacksmoke, blackmarks, and no doors on his little ford.
Old Aug 7, 2009 | 04:41 PM
patdaly's Avatar
Originally Posted by ljutic ss
The worst thing you could do to any internal combustion engine is to lug it.
I guess the question then is, what is considered lugging to a Cummins?
Mine pulls very cleanly without too much of a load right from idle...... Heck, I can just let out the clutch without throttle and it never even drops the RPMs.....
I guess I wouldn't try and leave from the stoplight at 500 RPMs.
Old Aug 7, 2009 | 04:54 PM
Ace's Avatar
Ace
I suppose if you define all the terms, a case could be made for the 8cyl as the better "lugger." As has been said, lugging is not good, the Dodge will pull out fine with no throtle at all, yada, yada. But what is lugging?
Low RPM load. Key word "load." Give the Cummins enough fuel under load with timing at low RPM and you're going to see pistons in pieces. It's simple math. 8 hits equals more smoothly applied power for a single turn of the crank than 6.
Is there a practical application for this? Not in the automotive world. Maybe for the big ship diesels running at max 300rpm with 16 cylinders. Methinks not if you are going to drive a pickup truck in a sane manner. Ford guys will grasp at any straw sometimes.
Simple math, and a facetious argument. I'll take the Cummins anyway.
Old Aug 7, 2009 | 05:01 PM
rednekroper05's Avatar
I dont know if this is true but i have heard that on the old two-stroke diesels if you lugged them down enough they would actually reverse and run backwards.
once again dont know if this true but while we are on lugging I thought i might see if anybody else had heard it
Old Aug 7, 2009 | 08:08 PM
LeonT's Avatar
Originally Posted by randallp84
My wife was in Tucson last month visiting my brother and we got a letter in the mail from the Tucson police dept. a couple of weeks ago with a picture of her in the truck in my signature with a fine for like 70mph in a 45. $215 or something like that. I thought about taking a picture of $215 cash and sending it to them like I read about somebody doing. I wonder what they would think of that.
Don't respond to that letter. In Arizona you have to be "personally served" with a citation. Just ignore it, and it will go away. I doubt that the TPD will send a process server to Hobbs, NM to serve you. Also, if you get a FedEx letter from Tucson, just refuse to accept it. They have tried that one too, in an attempt to get you to sign for it so they can prove "personal service".
Everyone here hates the photo radar.
Old Aug 7, 2009 | 09:19 PM
ljutic ss's Avatar
I would consider lugging as running any engine at such a low RPM with a load at a gear ratio, that when extra fuel is given, there is no ability for RPM to pickup. This can cause piston slap and rod&main bearings being hammered. Harley Davidson owners very well what lugging is.
Old Aug 8, 2009 | 01:27 PM
morpheus's Avatar
To the OP. Find a 2% to 6% grade. Take both trucks out there with a 10K load. Stop with the load on the grade. Now, with no "gas" pedal input, let the clutch out and see which one dies and which one takes off. Yes, that's at idle. A Chevy won't. A Ford won't. Only Dodge is capable of that feat. Ford and Chevy have crappy pedal modulation and you'll never keep the motor running besides the lack of power at idle.
Old Aug 8, 2009 | 02:13 PM
ljutic ss's Avatar
Where did all your scientific information come from? Is that with 3.73, 4.10. 4.30 or 4.56 rear? Is that in 1st., 2nd., 3rd., or 4th. gear? Just curious where you seen or read about this experiment.
Old Aug 8, 2009 | 04:29 PM
morpheus's Avatar
I used to work at DCX as a Design Release Engineer and helped perform said tests.
1st gear start. Rear gear doesn't matter.
Old Aug 8, 2009 | 04:44 PM
nelrod's Avatar
[QUOTE=sallyman1;2546031]A buddy of mine says the 5.9 is a decent engine -
Sal, if you ever need a sheep picked out in a herd of goats --------------
HE IS YOUR MAN
Old Aug 8, 2009 | 05:03 PM
correction rear gear does matter and this comes from real world experiance. The taller the gears the more it takes to get in to motion. For example a 4.56 will take less to start moving than a 3.73 will.
Also what is this stuff about testing on a grade.
Old Aug 8, 2009 | 05:09 PM
morpheus's Avatar
WOW, I didn't know that. The questions were pertaining to "the test".
Prime example of difficulty of starting on a hill, where you are on the brakes and trying to start the truck in motion. Riding the brakes and the go pedal is difficult, so it's designed to allow you to start off at idle, with no input.
Old Aug 8, 2009 | 05:17 PM
gadget.35-06's Avatar
Oh, and I agree with your comment about Arizona in your location. My wife was in Tucson last month visiting my brother and we got a letter in the mail from the Tucson police dept. a couple of weeks ago with a picture of her in the truck in my signature with a fine for like 70mph in a 45. $215 or something like that. I thought about taking a picture of $215 cash and sending it to them like I read about somebody doing. I wonder what they would think of that.
They'll just send you a picture of handcuffs
Old Aug 8, 2009 | 05:25 PM
[QUOTE=morpheus;2547415][QUOTE=rednekroper05;2547413]correction rear gear does matter and this comes from real world experiance. The taller the gears the more it takes to get in to motion. For example a 4.56 will take less to start moving than a 3.73 will.
Ok then did the chevy, dodge, and ford in the test that you mention all have the same rear gearing? If so what gear?
Old Aug 8, 2009 | 05:40 PM
ljutic ss's Avatar
So tell me if one truck has 3.54 rear gears and another truck has 5.38 rear gears, there is no difference in tests.
