Disable 4wd in 4 L range ?
Old Oct 15, 2008 | 07:55 PM
Valv's Avatar
I searched for 1/2 hour but could not find it. I know there's a way to add a switch to disable the front wheel engaging when shifting transfer case to 4L.
It's used to back up or move trailers. There were some posts a while ago but I cannot find anything.
Does anybody know anything about it ?
Old Oct 15, 2008 | 07:59 PM
bnold's Avatar
Here is the thread I made a while back... Not sure how it applies to you third gen folk though... All 3rd gens have AAM or was it a transition thing? No vac motor on the AAM IIRC
https://www.dieseltruckresource.com/...d.php?t=126682
Old Oct 15, 2008 | 09:08 PM
Valv's Avatar
That's exactly what I was looking for Bnold, NOBAMA 08 !!!
Wait a minute, whoops I meant no 4wd when in 4 low, great writeup !!!
I think there's a way to shut off the motor on a 3rd gen.
Old Oct 15, 2008 | 10:05 PM
RAMRODD's Avatar
The only way to get 2 wheel drive low range is to put in a Dynatrac Free spin hubs kit.
Old Oct 16, 2008 | 07:29 AM
spitfire9137's Avatar
Yea, like ramrodd said, no way to do it on a 3rd gen unless you buy a locking hub kit. They changed the axle mid way through the 02 production year if i remember correctly. So that means no go for any 3rd gen.
Old Oct 16, 2008 | 08:01 AM
Valv's Avatar
Yep, it was as quick as looking underneath the truck to find the answer. We don't have an actuator anymore.
Old Oct 16, 2008 | 10:10 AM
05 CTD2500's Avatar
... or just pull the front driveshaft, but then of course no 4wd.
Old Oct 16, 2008 | 06:17 PM
Valv's Avatar
I don't think it's very reasonable every time you backup you take the driveshaft off, isn't it ?
And the "no 4wd" that's exactly what we were trying to achieve.
Old Oct 16, 2008 | 09:04 PM
RAMRODD's Avatar
I really like have 2Low again. It is so nice for pulling out of a field on to the road with no jerking from the 4 wheel drive!!
Old Oct 17, 2008 | 07:06 AM
LongRanger's Avatar
Are you guys able to get back into 2High with the Dynatrac hubs without coming to a complete stop? Thanks.
Old Oct 17, 2008 | 08:03 AM
RAMRODD's Avatar
Yes I can get low range to high range without stopping. I usually go from 4th gear low to 2nd hi without stopping. What I find that works the best is push in the clutch put trans in Neutral(Hold in clutch) then pull the transfercase lever to Neutral give it a couple seconds then shift to Hi range then put the transmission in gear and let out the clutch. I do this all the time smooth as glass.
Old Oct 17, 2008 | 03:15 PM
Hintz's Avatar
Or pull the front driveshaft
Old Oct 17, 2008 | 06:23 PM
Desert Dually's Avatar
Talking
oh my
btw, somebody already mentioned that
i'm just funnin' ya, man!
Old Oct 20, 2008 | 08:17 AM
LongRanger's Avatar
Thanks Ramrodd. I am curious to see if the manual hub option would help an automatic take off with a heavier load by starting out in 4L and then moving to 2H. Any idea how fast you are moving when you make the shift? 10mph or so?
Old Oct 20, 2008 | 11:51 AM
Hayseed's Avatar
The electronic shift transfer cases are a pain to shift while moving or even at a dead stop for that matter!! I guess I'm just not used to waiting for anything to do it on its own. GIVE ME A LEVER TO PULL!!!! Sitting in the road with a big load waiting for the transfer to shift is no fun when a semi is coming up fast!!
