Difficult CODE to understand
Old Nov 3, 2007 | 06:18 PM
ollie32's Avatar
I turn my truck on today and the engine was vibrating pretty good at Idle. I check the code on the ignition and found that it was displaying
P0633, something to do with the SKIM KEY NOT PROGRAMMED?
I read up on it and see that it has something to do with some king of programming?
My truck is a 2003 3500 stock other then lift pump and commander. The dealership just did a reflash which has helped out with cold starts. Curious why a code is showing up??
Does anyone know?
Old Nov 3, 2007 | 06:38 PM
53 willys's Avatar
SYMPTOM PO633-SKIM SECRET KEY NOT ENTERED
WHEN MONITORED
While the key is on.
SET CONDITION
The SKIM secret key was not calibrated into the ECM.
POSSIBLE CAUSES
Improper ignition key is being used
Skim DTC's
Skim not calibrated properly</p>
Old Nov 3, 2007 | 06:40 PM
J BODY's Avatar
Don't worry about it. Skim module didn't see the ECM while it was "offline" during the flash. Tech probably could have gone back in and cleared all dtc's after the flash, but it's really no big deal.
Journier
Nov 2, 2004 02:04 AM
mytrucksaslug
Oct 21, 2004 05:15 PM
vtailflyer
Feb 29, 2004 07:55 PM
More Power
Feb 3, 2004 06:01 PM
Jones0027
Feb 6, 2003 09:16 PM
