Differential breather?
Old Dec 18, 2009 | 07:21 PM
jeramy125's Avatar
Earlier as i was walking up to my truck i noticed a hose hanging down in the front end. I get underneath and it goes into the top of the differential. The end that was hanging down looked like maybe it got caught on something and was torn right at a clamp. I routed it along the brake lines with the end facing down to avoid water getting into the diff. I'm guessing this is just a breather, but not 100% sure. Do I have anything to worry about or is this fine?
Old Dec 18, 2009 | 09:00 PM
dodge35000's Avatar
There should be a metal clip on the end of the hose the clips on to the shock tower.
The hose should not be upside down as it has a plastic check valve on the end to prevent water from getting in.
Old Dec 19, 2009 | 08:55 AM
jeramy125's Avatar
yea, but its nothing to worry about right?
Old Dec 19, 2009 | 12:23 PM
1985cucv's Avatar
no just clip it up with a zip tie to the shock tower the clips come off easily. clip it anywhere actually i see you have a 4 inch lift it might have jsut pulled it off because your truck sits higher. tie it to the frame really anywhere and youll be fine.
Old Dec 19, 2009 | 10:48 PM
shep1's Avatar
I would make sure the plastic check valve is in the end of the tube.
Old Dec 20, 2009 | 10:12 PM
Dr.Dizzle's Avatar
I agree! Mud daubers may create a blockage in the tube if you leave it open to the elements.
Superduty12v
Apr 21, 2005 08:29 AM
jethroish
Mar 7, 2003 09:57 PM
Jones0027
Nov 4, 2002 07:33 PM
