Diesel Kleen + cetane boost
Old Aug 11, 2008 | 10:34 PM
fishermantink's Avatar
Has anybody used Diesel Kleen + cetane boost? As always, I am leary about putting anything in my fuel tank that I am not familiar with. I am more concerned with making sure that my injectors are properly lubricated while using ULSD, and this stuff claims to be good for that.
Old Aug 11, 2008 | 10:39 PM
rip 112's Avatar
I use it all the time. I like it, but I can't say it noticeably helps. Its at a good price and it does lubricate fairly well.
Old Aug 11, 2008 | 11:13 PM
RamWheelsBy4's Avatar
I have ran PS Diesel Kleen and MMO mix in every tank for the last 80,000 miles. It did seem to quite it down a little when I started. At this point I don't know if it helps or not, but it has not hurt anything. The couple of times I had to fill up with out my mix around I could swear the engine was a little noisier, but that is probably just mind over matter. It is cheap insurance for a little extra lubrication and cleaning, especially with the ULSD diesel.
Old Aug 12, 2008 | 02:53 AM
chipmonk's Avatar
contains high levels of solvents (lots of acetone IIRC). some diesel mechanics say regular use of fuel additives with high levels of solvents will cause injector/pump problems in the long term.
Old Aug 12, 2008 | 06:58 AM
MikeyB's Avatar
I don't think Diesel Klean contains acetone (a ketone). But I do know it has ammonia, you can smell it. Also contains ethylbenzene and xylene.
MikeyB
Old Aug 12, 2008 | 08:02 AM
cranberry's Avatar
MikeyB
ethybenzene is probably the centane booster.
Never had a problem with it. I Dont run it in my '07 but everything else it has been ok ('02 P/Stroke, '94 IDI, '54 D4 Cat, '92 cummins, '98 cummins,etc) I dont use it every time though either.
Old Aug 12, 2008 | 08:52 AM
rip 112's Avatar
I do alternate between that and BG for that reason. Just for safety
Old Aug 12, 2008 | 09:39 AM
Roperteacher's Avatar
Despite the test, I have great luck with Lucas and Howes. BOTH are NON-Solvent! My truck HATES additives anyway, but she really seems to like these.
Old Aug 12, 2008 | 11:11 AM
Chip's Avatar
Stanadyne Performance Formula every fill up.
Old Aug 12, 2008 | 03:32 PM
chipmonk's Avatar
MikeyB
thanks Mikey. i know that acetone, xylene, and petroleum naptha seem to be the most common solvents found in diesel additives, and somtimes it's hard to remember which products contain which solvents.
i know that some Stanadyne products are more than 50% solvent by weight.
Old Aug 12, 2008 | 07:00 PM
megacabdad's Avatar
I run the Power Service almost every tank full. 37K so far without any problems. Don't know if it's needed or not, the one issue of Diesel Power I read awhile back had a write up about, and that sold me at the time.
The more I learn though, I'm not so sure what to believe and not to believe about DP anymore.
Old Aug 12, 2008 | 07:44 PM
Thanks guys, appreciate all the input and advice. Definitely a big help.
Old Aug 13, 2008 | 01:58 AM
chipmonk's Avatar
additives that have high levels of solvents will initially seem to make your truck run better. the solvents will clean the injectors and increase fuel mileage, but over time they will strip the lubrication film between the injector needle and nozzle, sometimes causing injector failure due to needle scuffing and needle side loading.
Old Aug 13, 2008 | 08:02 AM
Sprinter17's Avatar
Muted User
But PS has lube in it, and did pretty good on the bearing scuff tests floating around the Internet with the other additives tested.
Old Aug 13, 2008 | 02:05 PM
chipmonk's Avatar
note in my post where it says 'over time'. the additive lubricity test that has been posted several times here, was a one time test done in a lab, so it certainly can't give you any info on long term injector damage.
the chance of additives causing injector damage has to do with how much solvent is in the product, how much you use, and how often. if an additive contains a lubricant (almost all do), what is the % of lubricant compared to solvent? over time, the higher % of solvent can cause injector damage by breaking down the lubrication film between the needle and the nozzle- something specifically noted in a Cummins bulletin, as a cause of CR injector failure.
