Dies at 175 at degrees
Using a buddies truck for a little bit but it has an issue. Truck is an 03 2wd manual with the small bully dog tuner with a little over 200k miles. I forget which model tuner it is. Truck starts and runs great but as soon as it approaches 175 degrees on the coolant temp it starts missing, running rough, and eventually dies. Does it while driving as well. The only code that shows up on occasion is one for the VP44 which is odd. Monitoring rail pressure while the truck warms up it slowly starts dropping then just quits. Unplugging the fca while running makes no change in how the truck runs or what is displayed for rail pressure. Im at a loss and have no idea where else to look. Help is greatly appreciated.
Unless you removed the tune and returned the engine to stock, I believe the settings will remain in the ECU. Try hooking the BD back up and follow the procedures to "return to stock settings" or at least look up the defuel settings that may be in place.
Remove all tuners and boxes first to verify its no an electrical glitch.
If it still does it, retorque or replace the cross over tubes in the head. Typical problem, the dropping rail pressure is a classic symptom.
vintovka
Apr 30, 2012 12:38 PM
abc4yew
15
Aug 18, 2006 11:10 PM
robert chilton
Jan 16, 2006 02:44 PM
