Deeper tranny pan lower temperature?
Old Aug 23, 2007 | 12:37 PM
ArXane's Avatar
Are the deeper transmission pans that hold more fluid proven to lower fluid temperature? I understand that more fluid is better.
Old Aug 23, 2007 | 12:40 PM
Rob C's Avatar
I put a PML pan on mine that has an extra 2 quarts capacity and I didn't see any change.
Old Aug 23, 2007 | 02:07 PM
soulezoo's Avatar
DTR 1st Sergeant
I have a mag-hytec double deep pan-- I believe that is good for an additional gal. of fluid. I don't remember really, so it is at least 2 qts. for sure. In any case, to answer your question, it simply takes longer for the entirety of the fluid to heat up. Once there, it does not mean the tranny as a whole runs any cooler than it normally did. What it does mean is the fluid will last longer having made fewer trips through the system in the same time and, probably more important and to the question at hand, when flogging the motor and tranny and making all that heat, it takes a fair amount longer to reach those higher temps that can be damaging to the fluid and in turn the tranny. Call it extra protection for that. A side benefit is that if you have a leak or something goes wrong and you lose fluid, you have that extra 2-4 qts of reserve capacity over stock that can be lost before a problem really starts. That is by virtue of the pick up tube and filter extending lower into that deep pan.
Old Aug 23, 2007 | 03:38 PM
ArXane's Avatar
Thanks guys, I think that answered my question.
Old Aug 24, 2007 | 03:24 AM
TexasCTD's Avatar
Just an FYI, the Mag Hytec DD pan adds an additional 4 quarts of fluid over stock.
Old Aug 24, 2007 | 10:22 AM
soulezoo's Avatar
DTR 1st Sergeant
That's what I thought -- Thanks!!
and it is the Mag-Hytec "deep pan" that gets 2 quarts extra.
Old Aug 25, 2007 | 10:34 AM
XLR8R's Avatar
So, does the Mag-Hytech DD pan add a gallon or 4 quarts?
Old Aug 25, 2007 | 01:15 PM
TexasCTD's Avatar
NO NO NO....it holds 3.785 liters.....
Old Aug 25, 2007 | 03:04 PM
XLR8R's Avatar
Oh OK - for some reason I thought it was 256 tablespoons.
krazydher
Feb 20, 2008 02:18 AM
VIPERBLUELX
Aug 6, 2006 11:13 PM
jay05torque
Dec 9, 2005 07:29 PM
Eagle Driver
Mar 8, 2004 01:22 AM
