Cummins vs PS vs Dmax
Old Sep 13, 2005 | 07:12 PM
eastmentCTD600's Avatar
Originally Posted by bluepp
Well you'll never need to wind the cummins anywhere near 4200. With the 48re auto locked in 3rd gear with stock gear ratio of 3.73 the cummins will run 85 mph at 3300 rpm redline. and bring a 15000 lb trailer right along with it. And when you hit the grade you cant pull in third you hit 2nd at 60 mph and never get above 3300 rpm.
But mostly you will cruse at 60-65 with that 15000 lb trailer in overdrive at a nice pocky 18-1900 rpm. Tool over all freeway viodocks and up most grades and never come out of 4th lockup. And you will never need to BOMB up the power. Keep her stock. You'll never need more then 325 hp and 610 torque.
Simply put lower RPM = less piston speed = longer engine life. Not to mention the long full skirt on the pistons.... great motors
Old Sep 13, 2005 | 08:36 PM
bluepp's Avatar
Exactly , eastmentctd600, No question about it as to which engine is best for towing .
Old Sep 13, 2005 | 09:01 PM
pecandude1's Avatar
i have a duramax and a cummins both 05s both autos and both 3.73 gears and 2wd. the duramax pulls as good as my dodge up to about 65mph. but after 65mph you can tell the dodge has more pulling power as when you climb a hill the dodge can pull it in overdrive and on that same hill my duramax will have to downshift to pull it
draskobnsf
17
May 29, 2007 08:29 PM
hendrix316
Apr 24, 2006 10:42 PM
MOJO1
Competition / Pulls / OffRoad
Apr 12, 2006 11:38 AM
1sttruck
Oct 20, 2003 05:33 AM
SjLingenfelter
Oct 2, 2003 09:28 PM
