Is this a Crank Case Vent or what?
Old Feb 12, 2011 | 08:42 PM
carri56's Avatar
Question Is this a Crank Case Vent or what?
On top of engine but underneath the plastic cover there is a square black box that i'm assuming is a crank case filter / breather. Is this correct ? Is there any maintenance or replacement required ? How often ?
THanks
Old Feb 13, 2011 | 12:14 AM
tryNto's Avatar
It is.
Mine has no filter it it, just the black box with the hoses hooked to it. So I'm guessing, No changing ever...
Old Feb 13, 2011 | 06:15 AM
Dodgezilla's Avatar
I think there is a filter in there but you just can't see it. I just had mine off and I sprayed a bunch of carb cleaner through it to try and clean it. I don't know if it did anything or not. One thing I had not realized is that one hose exits under the truck and the other goes back into the block.
Old Feb 13, 2011 | 02:45 PM
07 ThunderRoad's Avatar
Genos Garage has the replacement filter for the 5.9 up to 2005. The 2006 & 2007 5.9L does not have a replacement filter. If the 06 -07 plugs and / or dripps oil the cover must be replaced.
DodgeCowboy
33
Oct 25, 2008 02:34 AM
JSPulliam21
Apr 12, 2007 08:56 PM
Thundercloud
Nov 9, 2006 06:45 AM
dbossdiesel
Oct 17, 2006 03:04 AM
CTD NUT
13
Jan 4, 2005 04:34 PM
