Cp3 Leaking Again
Old Sep 26, 2006 | 05:13 AM
  #31
rich2500's Avatar
I wonder if II or someother company could take out leakin pumps and rebuild and upgrade em for us?
I would not see why they could not
Old Sep 26, 2006 | 10:00 AM
  #32
sawboywv1's Avatar
mine is also a different number than from before. original one lasted 30k, then leaked every 20k after that. this one is also a new part number.
4th pump in 72k miles is BS. dealer has been very cool about it.
Old Sep 26, 2006 | 02:23 PM
  #33
Hounddog's Avatar
Don't remember if on here or TDR but a member fixed his own.Said it had to be kept super clean but he opened his up and match up the internal o/rings with same size but thicker and put it back togather.Claim there was nothing difficult about it.Some torx head screws and split it open.
Old Sep 26, 2006 | 05:18 PM
  #34
B.Law's Avatar
I took the CP3 I got off eBay apart and noticed all the o-rings, I was wondering rich2500 if these were the ones you replaced, now I know. I think the only thing tough about the o-ring replacement would be just getting the CP3 off the truck itself. I'm not a 100% sure, but don't you need a speacial gear puller to get the CP3 out? As far as the o-ring replacement itself, there's not too much that could go wrong, just stay clean.
Old Sep 26, 2006 | 06:04 PM
  #35
XLR8R's Avatar
We re O-ring pumps, cylinders and such at the shop no problem; just make sure to get the correct O-ring material, thickness, and diameter.
Old Sep 26, 2006 | 07:55 PM
  #36
Hounddog's Avatar
The post I read was he got same diameter but went to a thicker o/ring.Stated he thought dissimilar metals(rate of exspansion and contraction) caused the leaks.But anyhow went to thicker o/rings and reinstalled with no leaks.
Old Sep 26, 2006 | 07:58 PM
  #37
wap's Avatar
wap
Hounddog, I dont meen to be rude or anything but try rereading these 3 pages, start to finish, I am pretty sure that is Rich you are talkin about and he stated all you have said in this thread.
I went back and reread, try page one post #8
Old Sep 26, 2006 | 08:23 PM
  #38
rich2500's Avatar
yes all those o-rings between the two halves of the pump are the leakers
yes a gear puller is needed to pull the pump gear,I just use a steering wheel puller that I shortened the center bolt so I don't have to pull the fan off,you must be careful though because there is a lock washer behind the nut holding the gear on and you don't wanna drop it.
yes clean is very important,any dirt that passes through the pump will end up in the injectors.
Old Sep 26, 2006 | 08:43 PM
  #39
Hounddog's Avatar
BY Jimmy your right!
lilsuzuki4x4
Sep 1, 2011 01:50 AM
wexman
14
Jan 13, 2008 09:32 AM
b84u
Feb 20, 2006 01:04 PM
sawboywv1
24
Dec 13, 2005 10:36 AM
sawboywv1
Nov 1, 2005 10:01 AM
