cp3 leak repair
Old Jan 28, 2007 | 05:28 PM
rich2500's Avatar
parts list
1- 25x36x7 harwal seal this is stock size
1-25x37x7 harwal seal this is stock size
1-2.50x54.00 ame o-ring this is 1mm thicher then stock
6-2.00x7.00 ame o-rings these are 1mm thicker then stock
1-2.00x67.00 ame o-ring this is stock size
cost for me was about $25.00 but I get the parts through my old mans business account(automotive machine shop) so I get a bit of a discount.
all the seals and o-rings are made of viton(very important)
Old Jan 28, 2007 | 05:31 PM
rich2500's Avatar
Excellent!!! Any seals on the FCA? Any reason to pull it and check?
really no reason to pull the fca, the pump I used for this write up was a spare pump that I took the fca off of for another pump
Old Jan 28, 2007 | 05:37 PM
rich2500's Avatar
I know I'll probably get laughed at for asking this, but I'm going to anyway....
Is there a sealant that will stand up to diesel fuel that could be run along the seam all the way around the outside of the pump to keep it from leaking? You know, like sealing a valve cover.
What would happen? Just wondering....
assuming your looking to do this instead of replacing the seals permatex would probably work for a while but eventually the leaking fuel is going to push out somewhere
Old Jan 28, 2007 | 05:50 PM
53 willys's Avatar
So where would we order the parts from??
Old Jan 28, 2007 | 06:00 PM
no_6_oh_no's Avatar
I assume all measurments are millimeters?
Any idea of TQ specs on the bolts?
Thanks again.
Old Jan 28, 2007 | 06:06 PM
rich2500's Avatar
this is where I get the parts
Philadelpia Ball and Roller Bearing Co.
1346 Centre Ave.
Reading Pa.19601
phone# 610-376-7500
Old Jan 28, 2007 | 06:10 PM
rich2500's Avatar
yes all measurements a mm
I have not been able to find torque specs for the bolts so I just snug them all real good by jumping around the bolt pattern.finding info on these cp3's is next to impossible
Old Jan 30, 2007 | 07:23 PM
Polish Rocket's Avatar
Rich2500,
Thanks for the mini presentation. Very informative! After the replacement you have no leaks? Thats great if you don't! Now only if dodge would smartin up and fix their own problems. That would make life much easier.
Thanks
Old Jan 30, 2007 | 08:12 PM
rich2500's Avatar
It would actually be real easy for bosch to solve the problem,make the whole pump steel why the two different metals is beyond me
Old Jan 30, 2007 | 10:32 PM
rockcrawler304's Avatar
Thanks for the write up!!
Old Jan 31, 2007 | 08:02 AM
sawboywv1's Avatar
C'on why 2 different materials..... Cost, COst,COSt,COST!!!!!!
Everything, every detail is cost crunched to death, even to the extent of loosing customers. So they **** off 1 in every 1000 customers. So what.
The Aluminum & machining of aluminum is alot cheaper & thats what Bosch looks at. What I really don't understand is why they don't use larger o-rings??? ****.
Old Jan 16, 2008 | 04:28 PM
Tree DR's Avatar
How bad can the leaking cp3 get will it actually run fuel out on the ground or just seep all the time?
Kind of wondered if it's an emergency or just need to get it done some time?
Old Jan 16, 2008 | 05:53 PM
gmctd's Avatar
What happened to the pics? Red 'X's in white squares are not worth a thousand words, eh?
Old Jan 16, 2008 | 06:05 PM
53 willys's Avatar
mine just seeped when ever the engine was running....I never had any drops cause it was dropping on to the fan wiring harness and filling up the wire loom instead of dripping
he must have moved the photobucket links
Rich any update on this?? has your pump ever leaked since you did this???
my warrantied pump is leaking all ready(1yearold) if yours is still dry I am going to do this instead....
Old Jan 26, 2008 | 05:42 PM
rich2500's Avatar
sorry folks been getting alot a pm's about my pics not working,I was having problems with my photobucket account,so I switched to imageshack for my photo hosting,unfortunately thats why the pics don't work and I deleted them off my hard drive,If enough folks would like I can pull my spare pump apart and take photos again,I'm not on here much anymore because I got rid of my truck and went back to a gasser(f-250 V-10) just could not justify the diesel anymore.for an update I just got rid of the truck in dec. and up to that point my pump never leaked again.So let me know who would like the pics back and if enough want them I will do it.
