could this be ball joint problems???
Old Jun 13, 2006 | 05:57 PM
kully560's Avatar
going down freeway on straight road in left lane and the road has a slight pitch to the left, truck starts to pull that way . middle lane is fine if level. does the same thing in the right lane if lane pitches to right truck want to go slightly that way .just starting to notice this .is this the start of ball joint problems .2003 with 72000 miles
Old Jun 13, 2006 | 06:50 PM
Bad Ramer Jamer's Avatar
Mine does the same thing really bad. I've switched the front tire's around and it change's thing's,,,wich tells me it's not the crown in the road,,,wich you'll be hearing. I have gotton different set's of tire's that do just fine. I just put new one's on and need to try switching them.
I know this wasn't an answer, but just wanted to let you know you're not alone.
Old Jun 13, 2006 | 07:20 PM
kully560's Avatar
thanks jammer I just switch to new tires had the oem michelin ltx with 68000 on them and thought it was them .so I went to toyo ht 265/70/17 and same thing do not know .kully
Old Jun 14, 2006 | 08:22 AM
Christov's Avatar
It could be the roads you are driving on. When the pavers build the roads, they put a crown on the roads to allow for water drainage during heavy rains. If you are in the center lane which is NOT crowned and don't feel the problem, it is NOT your truck. The outer lanes have a curvature towards the outside for drainage. My motorcycle tires attest to this too, since they usually receive more wear just left of center on the tire.
72dart
Jun 19, 2012 10:42 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
FDC
Jul 16, 2007 12:51 PM
Treangen
May 7, 2007 03:10 PM
