Converting my Dually
Old Dec 1, 2004 | 04:44 PM
Ramasaur's Avatar
The hubs may be different, but the axle length is not, pull the hub and put a SRW hub on there... they do come off pretty easy! Problem fixed.....
Old Jul 19, 2006 | 10:46 PM
cromulius's Avatar
Ok so the front hubs can be changed and can you have non rotatable tires and fix the wider rear axle with some rim offsets?
Old Jul 20, 2006 | 09:11 AM
Nav's Avatar
Nav
It may just be easier if you find someone who wants to "switch" rear ends with you. Swap out the axle and bed. All you will be out is the few bucks for a matching paintjob.
Just a thought, unless you are looking for a "project"
Nav
Old Jul 20, 2006 | 09:57 AM
TonyB's Avatar
If you only want 4 wheels, why not go to a super single, and leave the bed, axle, and what not in place? At least you'll still have the weight capacity, if you need it!
HTH
Tony
Old May 13, 2008 | 07:49 PM
Smokeshowin''s Avatar
I know this is an old thread but I have to ask,What center cap do you use for the rear when you do the srw conversion on a dually.I can't make my 2500 caps fit the rear drw axle.
Old May 13, 2008 | 08:12 PM
NDanecker's Avatar
The axle housings are the same but the axle shafts are longer to accomodate a spacer between the hub face and rotor mounting.
I did a srw to dually conversion on an 04.5 with AAM axle. Here are some pics of each axle.
https://www.dieseltruckresource.com/...62&postcount=4
The front is the same. Simply remove the bolt on spacer.
The bed will have a 23 holes each side (I think it was) which will need to get covered up. I also think they cut the fender for tire clearance as my body shop guy needed to notch the wheel lining a little for the fender right above the tire instead of cutting the fender. I can take a picture to help explain this if you want. Body work is probably the most expensive cost. Look on ebay or other for a complete take-off bed, IMO.
Good luck!!!
Old May 14, 2008 | 02:51 PM
heres a pic of what you will find once you take the dually bed sides off....
wayne74447
Jun 16, 2006 05:18 PM
dodgeboy59td
Jan 17, 2006 04:46 PM
budsowner
22
Sep 1, 2005 05:00 AM
richard
Nov 16, 2004 05:51 PM
Mostwanted
Aug 25, 2004 06:54 AM
