Compression Test Results
Pulled out my old injectors and waiting for my Flux's 1.8's to get here next week. So while there out I figured I do a compression test on all cylinders. The engine has 252852 miles on it. If you guys don't mind, I would like to hear your opinion on my results, thanks. Cylinder: #1 495 PSI, #2 500 PSI, #3 500 PSI, #4 500 PSI , #5 520 PSI and #6 490 PSI.
Just for clarity, when doing a compression test, it is always better to do it dry and then oiled. It allows the operator to do some discrimination between ring and valve leakage, if leakage is present. I think these results are pretty much perfect.
