commonrail to 12 valve swap.
Old Nov 5, 2011 | 11:20 PM
sea prowler's Avatar
putting a 12 valve in an 03 will the manifold and turbo fit off the 305 ho port spacing looks close . old engine is out of a 92 160 horse.
Old Nov 6, 2011 | 12:14 AM
rebal's Avatar
you will be going from round ports to rectangle ports but I gota know why the swap and how you gona get all the electronics to work?
Old Nov 6, 2011 | 08:39 AM
ironbrew's Avatar
This is a swap I considered, and passed on because of all the electronics. As to the why? Get rid of a lot of the electronic and electric engine controls and components. Dead alternator? Keep driving till you get to where you can repair it. Injectors? A fraction of the price... Lots of reasons to like the 12 valve.
Oh, and if you have an auto, there are controllers available, but I was thinking of trying to get a 47rh instead.
Too bad I'm an electrical clutz...
Old Nov 6, 2011 | 09:10 AM
03 engine is dead.2 valves block split cylinder3 .a valve failure and prev owner ran truck till complete failure.as for electronics keep 03 computer use 03 senders install cam sensor in 92 for alt and tack and the 6 speed man should shift fine.Alco need injectors out of 03 for my other ram.ps have to swap the o3 cam gear into the 92 for cam sensor.had a guy in the shop yesterday who did all this with an 01 works great now 2 years running and the check eng light is not even on in truck.
Old Nov 6, 2011 | 06:12 PM
whiskers's Avatar
Something I've considered with my '02. Runs fine but hate the computer controlled crap.
Old Nov 7, 2011 | 05:02 PM
dieselfreak21's Avatar
I know some have P-Pumped the CR engines. Wouldn't that be easier and cheaper???
Old Nov 7, 2011 | 08:19 PM
the cr engine is no more good other than parts for my 2003 2500.but i would like to have a good p pump to throw on the old b were putting in.
CommonrailE350
16
Nov 19, 2007 08:20 PM
24Vford
32
Aug 20, 2007 09:51 PM
morkable
38
Aug 5, 2007 11:35 PM
Artsi_L
0
May 4, 2006 12:37 PM
pcburnout
Apr 10, 2005 12:42 PM
