Common Rail Design
just missing the injector return drain lines and it is a complete drawing
[return is needed, without it, there will be no pressure differential across the cartridge and injector can't fire. the solenoid doesn't mechanically lift the needle valve in the nozzle, pressure differential from the bypass opens it.]
in my opinion, all hpcr fuel systems should have flow limiters on the hp lines to the injectors, but i haven't seen a system yet that does
gdh11
98
Mar 8, 2005 12:30 AM
ddestruel
Jun 28, 2004 01:03 PM
