cold start up
Old Jan 20, 2007 | 05:22 PM
Hvytrkmech's Avatar
cold start up
Here's what happened, truck sat all day outside, temp was 18 deg. wait to start light came on as usual, I waited to start then started it and it fired right up and immediately went to 1000 rpm as it fired and stayed there. I shut it down appx. 30 seconds after I started then waited appx 30 seconds and restarted it to see if it would duplicate, it did not, it started up as it normally does, stayed at base idle then after a minute or so it went to 1000rpm. The truck has never done that before, but on a cold start if I don't engage the high idle myself it does go to high idle on its own.
Anyone ever have this happen and is it normal?
TIA
Old Jan 20, 2007 | 06:23 PM
CowboyDave's Avatar
Not me, It will start normal then the usual 1-2 minute later it hits 1000 RPM. I hope it was just a fluke, but it doesnt sound bad anyway.
Old Jan 20, 2007 | 06:48 PM
t-boe's Avatar
If it's cold enough out mine will do that.
Old Jan 20, 2007 | 06:50 PM
wexman's Avatar
Yes and yes. It depends on the ambient temperature, I think. Thursday morning here, it was 19*, and as soon as she fired, it went right to 1000 rpm. Last couple of mornings, it wasn't as cold, and it took at least 30 seconds before she idled up.
Old Jan 21, 2007 | 10:44 AM
BAD GRAVY's Avatar
that is normal it will also do that if you let idle after it is warmed up if the temps outside are very cold
Old Jan 21, 2007 | 11:30 AM
WICTD's Avatar
Mine has done that a few times that it has been below 20* and it has not been plugged in. It set a code relating to the grid heater one time but the dealer could find nothing wrong.
Old Jan 21, 2007 | 03:59 PM
Shanajustin's Avatar
It's normal. Mine does it both of the ways described. It has to be really cold to fire and go to 1K immediately.
Old Jan 21, 2007 | 04:22 PM
Hvytrkmech's Avatar
Thank you for all the replies, it is much appreciated
Old Jan 21, 2007 | 07:13 PM
bucknasty's Avatar
Ditto on that..Mine does it to, so does my buddies. Takes about a minute or so.
Old Jan 21, 2007 | 07:20 PM
chaos24valve's Avatar
Mine wont do it on start up, but after about 10 seconds or so it goes to 1200 ish. and stays there till I go some where. Sure sounds funny outside of it. And It doesnt even get that cold here. I think the low was 28 at the most.
Old Jan 21, 2007 | 09:41 PM
MRoman's Avatar
Mine did it this morning, it was 25 degrees outside. It seems like it only does it when it's in the 20's or less.
This I don't understand. Motor temp was about 170 degrees or so and I was waiting for the egt's to come down and it went to high idle. I also noticed it takes longer for the egt's to drop when it's cold out. Go figure?
bullfrog5.9
Jan 3, 2010 05:41 PM
CoolumConst
Oct 11, 2008 10:00 PM
yukon mike
Nov 28, 2006 10:51 AM
wings
Nov 8, 2004 05:32 PM
