codes where do I start
Old Feb 10, 2015 | 07:30 AM
regert's Avatar
So I started to work on my truck to get her on the road and I started it up the engine light is on, I checked codes and to my suprise I have a list:
P0107
P1762
P1754
P1749
P0483
P0243
P0480
P0642
Anyone know if these could just be caused by one sensor? truck runs and drives good.
thanks
Old Feb 11, 2015 | 06:44 AM
PWong's Avatar
P0107 = MAP Sensor low
P1762 = Gov Pressure Sensor offset
P1754 = TTVA
P1749 = TTVA Sensor low
P0483 = Cooling Fan Speed
P0243 = Turbo Wastegate Soleniod A Malfunction
P0480 = Cooling Fan 1 Control
P0642 = Sensor Ref Voltage 1 low
The sensors operate on 5VDC (Sensor Ref Voltage) which is supplied by the ECM.
A lot of sensors would cry when the the ref voltage is low.
Looked like you have the ref voltage issue (P0642).
You have a short somewhere that pull down the 5V circuit.
Check for wiring harness damage for the cooling fan. Not uncommon problem.
Check for wiring harness damage near/above the AC compressor. Not uncommon problem.
It could be the ECM, the wiring/connection of the 5V circuits.
I would reset/clear all the codes and drive it to see if they come back again.
Old Feb 11, 2015 | 07:08 AM
regert's Avatar
I've cleared codes and they come on right away with out the motor even running, what color wire am I looking for that could be broken?
Old Feb 11, 2015 | 07:15 AM
PWong's Avatar
Clear the codes.
Disconnect the connector for the fan clutch, located at the bottom of the shrould.
And try.
You don't want to see P0642.
Old Feb 11, 2015 | 07:17 AM
PWong's Avatar
http://www.rambodybuilder.com/2007/d...rwdoptions.pdf
Have fun.
Old Feb 11, 2015 | 10:20 AM
PWong's Avatar
Looking for wiring rubbing, bare wiring touching each other or touch the ground, broken etc.
exwrestler
Feb 5, 2010 09:34 AM
CoolumConst
Oct 11, 2008 10:00 PM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
