Codes I got on my truck
http://wiki.dieseltruckresource.com/wiki/Computer_codes
Here's the code descriptions. The above link is where you can bookmark to look them up yourself. Sounds like a f;ash update will cure most of them.
Nothing on P2607.....are you sure about that one?
P0541 Low Voltage On The #1 Intake Air Heater Relay
P0191 Fuel Rail Pressure Sensor Performance
P0514 BAT Temperature Sensor Rationality
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 18-022-06 DATED
JULY 13, 2006, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS
ARE HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION OF DTC
P0191 - FUEL RAIL PRESSURE SENSOR CIRCUIT PERFORMANCE.
THE DRBIII® FLASH FILES FOR THIS BULLETIN ARE AVAILABLE ON
DealerCONNECT.
SUBJECT:
Flash: 5.9L Turbo-Diesel Engine System Enhancements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Engine Control Module
(ECM) with new software.
MODELS:
2003 - 2005 (DR / DH) Ram Truck
NOTE: This bulletin applies to vehicles equipped with a 5.9L turbo diesel engine
(sales codes ETC and ETH respectively).
SYMPTOM/CONDITION:
The following enhancements are included with this software:
1. Improved engine cooling (radiator fan activation) and prevention of possible engine
overheat. When coolant temperature faults are present the radiator fan is enabled
(turned on) during vehicle operation.
2. Correction to oil pressure reading when engine is operating at higher engine
temperatures above 91°C (195°F).
3. Improvement to the Temperature Sensor Rationality Test to prevent possible false test
failures and the following related Diagnostic Trouble Codes (DTC's):
a. DTC P0071 - Inlet Air Temperature Sensor Rationality.
b. DTC P0111 - Intake Air Temperature (IAT) Sensor Rationality.
c. DTC P0514 - Battery Temperature Sensor Rationality.
4. Additional Water-In-Fuel (WIF) warning added to indicate that the operator has had a
WIF DTC P2269 and has continued to operate (drive) the vehicle in excess of 500
miles without draining the water from the fuel filter. The following is the new WIF DTC
that has been added:
a. DTC P0169 - WIF Too Long Error
DealerCONNECT.
SUBJECT:
OVERVIEW:
MODELS:
SYMPTOM/CONDITION:
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
Gypsyman
Aug 27, 2004 04:32 PM
