Code P 0069 light is on.
Old Jan 16, 2008 | 11:19 AM
twotirefire's Avatar
Hello guys and Gals, I don't post here very often but I have been searching the threads for code 0069 and have not found very much info. I did the key trick and got a code 0069 after my CEL came on today. Actually I am not sure if it is a check engine light or check gauges light, but it is yellow and looks like an engine block in the lower middle of the instrument cluster.
I read a few threads about having recently installed a quad, but that is not the case. All I have done to mine is load the SC 3805 Flashpaq and changed to a better air filter. Does anyone know where to look to clear this code? Thanks in advance! BTW, just came on while driving, put it back to stock when I got home, and it cleared it for about 15 miles, then came back on.
Old Jan 16, 2008 | 11:25 AM
vzdude's Avatar
DTR's 'Go to Guy'
http://wiki.dieseltruckresource.com/wiki/Computer_codes
P0069 MAP/BARO Correlation
Sounds like you need a boost fooler!
Old Jan 16, 2008 | 11:47 AM
I am going to check the connection and if that is good, I will remove the boost fooler and see if the codes clear. Thanks I will let you know!
Old Jan 16, 2008 | 12:11 PM
Pulled the bf and code cleared. I havent driven it yet but I bet it's fixed. Do you think that boost fooler is doing me any good anyway?
Old Jan 16, 2008 | 12:34 PM
vzdude's Avatar
DTR's 'Go to Guy'
Should be, if you are building more boost than factory! Most downloaders don't boost fool if I remember correctly.
Old Jan 16, 2008 | 12:38 PM
It sure seemed to help after the 3805, but not much before it. I think it did lower egts pulling the trailer loaded though, even without the programmer. Guess I better order another one!
Old Jan 16, 2008 | 12:44 PM
vzdude's Avatar
DTR's 'Go to Guy'
Call quad! Was the light on? May have just been a poor connection, and maybe it still has some sort of warranty on it?! Worth dropping a dime though!
stratos201proxl
Jan 16, 2014 11:04 AM
Joey-D
Dec 12, 2011 12:52 PM
Shaken71
Oct 13, 2007 09:18 PM
bway1341
Feb 11, 2007 04:14 PM
CTD NUT
Apr 5, 2005 04:45 PM
