Coasting or Hyperdriveing with automatic
Old Jun 10, 2008 | 10:04 PM
jpajax's Avatar
Will it hurt my trucks automatic tyranny if I put it in neutral going down a long hill when it tc is locked going over 50 mph.
Old Jun 10, 2008 | 11:31 PM
ptgarcia's Avatar
No. Just don't miss and put it in reverse!
Old Jun 11, 2008 | 06:41 AM
no_6_oh_no's Avatar
DEFINITELY!!! It won't come back out and things get ugly really fast!
Not sure it will gain you anything as the I believe the TC will unlock anyway, plus, the engine will defuel if it doesn't not need provide power. OD will over run if you just lift off the throttle.
It won't hurt anything but don't think it will gain you anything either.
Old Jun 11, 2008 | 06:58 AM
MikeyB's Avatar
Why? Fuel is usually shut off while coasting or de-accelerating in gear.
MikeyB
Old Jun 11, 2008 | 12:09 PM
steelblitzkrieg's Avatar
DTR Detective
IIRC as long as my TC isn't locked RPM's drops to idle level so why take the chance of shifting to neutral?
Old Jun 11, 2008 | 08:57 PM
Sevir's Avatar
it isnt going to make any differance at all. even if your TC is locked up above 50, your truck might be a higher RPM's but there is no load on the truck, it is the same as being in neutral
Old Jun 13, 2008 | 01:28 AM
Dieselnick's Avatar
Ya, don't put it in Park either.
Nick
Old Jun 13, 2008 | 09:07 AM
stealman1's Avatar
Its not the same as being in neutral. the gears slow you down when in gear. You can coast farther in neutral. Hypermileing works.
Old Jun 13, 2008 | 09:41 AM
matego's Avatar
madhat's monkey boy...
I believe that it does work but at what expense? To save a few diesel bucks you risk blowing out your $4500 auto by messing up one day. Personally I would not do it with a auto just for fear of grabbing the wrong gear and putting it into meltdown.
Old Jun 17, 2008 | 10:33 PM
jpajax's Avatar
Went out to check mileage on the old clock and it says 254.6 on 1/4 of tank of fuel so I guess between kicking it out of gear and the mystery switch it works. Will let you know when I fill up what mileage ends up. Fuel hear is $4.65 to $4.75 so you gotta do what you gotta do.
Old Jun 18, 2008 | 09:59 AM
no_6_oh_no's Avatar
The fuel gauge lies most of the time if you are using it for a reference don't rely on it. Fill the tank then run your calcs to get accurate info.
huckstep
Jan 14, 2007 11:25 AM
cincydiesel
Sep 14, 2006 04:44 PM
dave78
Dec 6, 2005 04:14 PM
mestdagh
33
Oct 4, 2005 08:38 PM
TheMoose
Oct 31, 2003 12:06 PM
